Did the Z3 Rack Conversion and It's Awesome
  • ClayW
    • Apr 2011
    • 377
    I did the Z3 rack conversion a few weeks ago and I have to say that it's awesome. The steering is tight and responsive. I was expecting a little difficulty because I have an airbag car, but it was a relatively simple job with great results. If your rack is leaky, do this conversion!
    1987 325e Commuter Project Blog
    1967 1600 Project Blog: www.TX02.blogspot.com
  • DEV0 E30
    • Oct 2004
    • 8896
    I had an E36 M3 rack in my previous e30, honestly a quicker rack is one of the best modifications you can do to your e30 possibly even before suspension. I plan to run a Z3 in my new car.
    Which Z3 rack did you purchase?
    • ClayW
      • Apr 2011
      • 377
      I bought the 1.9L Z3 rack. Blunt got it for me....can't recall the p/n. It was a Maval rebuild.
      • Holland
        • Nov 2008
        • 7212
        I can't wait to do this swap, my car seriously needs this.
        • mccor023
          • Jul 2011
          • 683
          Clay, I see you have a late model I am bout to do this next week. Did you have an problems with the firewall? Also was your car airbag or non airbag?
          Thanks.
          I love that people ask stupid questions so I dont have.
          • ClayW
            • Apr 2011
            • 377
            Thanks.
            Yep, my car is a 1991 sedan with an airbag.
            You have to notch out the firewall and make a plate to hold the firewall shaft seal. See the bottom of this page.
            Notching:
            New firewall seal plate:
            It's really not that difficult to do, but it requires some thought. See my swap here.
            • mulletman
              • May 2012
              • 801
              This will likely be the next mod my car gets, once I put my suspension back together.
              My issue is figuring out whether or not my car originally came with an airbag. It currently has an MTech2 steering wheel, with no bag.
              -It's a 1990. And yes, those had airbags, except for some really early ones. Mine is an August-1989 build. Really early 1990 model.
              -It has no airbag light on the instrument panel anywhere, like I would expect an airbag car to have. Can someone verify that the airbag cars actually do have a light?
              -RealOEM lists both airbag parts and non-airbag parts when I type in my VIN.
              Any other ideas on how to find out?
              • ClayW
                • Apr 2011
                • 377
                The difference is in the steering knuckle.
                Airbag E30 Knuckle:
                Non-Airbag E30 Knuckle (which needs modification):
                • mccor023
                  • Jul 2011
                  • 683
                  Just to clarify: non airbag needs knuckle modification but no firewall modification- and reverse is true for airbag?
                  • ClayW
                    • Apr 2011
                    • 377
                    Correct.
                    Airbag cars need the firewall to be modified.
                    Non-airbag cars need the knuckle to be modified.
                    • fronton
                      • Oct 2009
                      • 1262
                      type your vin into a BMW vin decoder
                      • mulletman
                        • May 2012
                        • 801
                        I did this. It doesn't say anything about an airbag, but it does list that my Mtech 2 wheel was a factory option, and not added aftermarket.
                        That would mean that my car is a non-airbag car, yes?
                        I haven't had a chance to look at the steering knuckle to verify.
                        • Polaris15
                          • Nov 2011
                          • 309
                          On my air bag car when i open the glove box it has an airbag warning sticker. Perhaps check your car for that?
                          • Wh33lhop
                            • 11705
                            Actually the Z3 rack may NOT require knuckle modification. E36 racks do, but the splines on the Z3 rack go deeper (oh baby) and may not require knuckle shortening.
                            The funny thing is, the Z3 rack is such a huge improvement over the stock rack but it's still not THAT fast. For instance, try driving a car with a z3 rack and then driving an Evo or a Mazda3.
                            paint sucks
                            • mccor023
                              • Jul 2011
                              • 683
                              I'm starting to think that is the case! I started this solo and after giving up attaching the knuckle to column and then knuckle to rack (w/ spacers installed). I separated the knuckle, inserted the top and installed rack to subframe w bottom half of knuckle. Now im looking and there is no way the spacers will fit, and Im doubting everything. Click image for larger version
