Just want to get some opinions out there and how you guys measure your height from fronts and rears. In the process of adjusting my coils and just cant get it tuned in. I know if differes from suspensions and spring rates but just numbers of what you guys ride? Is it just pretty much a "eyeball it" kinda thang?
what's your ride height?
If you're doing coilovers, you measure the amount of exposed threads.
If you just have springs/shocks, then it is what it is. Other than that, I don't understand the question.Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholicComment
I'm right around 12" from center of the hub to the fender; as tall as it goes for usage as a DD.
I use a set of scales to help get my measurements right also.- Josh
1990 325is
Need a shift boot?
Looking to buy shift boot frames, PM if you have one to sell
Here's what happens when you let the internet pick your license plateComment
Yes, my measurements all worked out the same. I have all my adjusters set about as tall as they'll go. One of my steering rack bolts is stuck so I don't have a skid plate on at the moment; I'd like to go lower.
- Josh
1990 325is
Need a shift boot?
Looking good man. Your height is about the same as mines right now. Plannin to go lower since I got the raceskid plate on there right now its just the company I bought my jom kit from left out my spanner wrenches so I can't adjust my coils at the moment unless I disassemble strut towersComment
For alignment specs and/or ride height adjustments BMW has us measure from the bottom lip of the wheel to the bottom center of the fender for comparing side to side.Comment
Thanks, I'm really happy with it overall. Can you use a strap wrench or lift the car and turn them by hand?Looking good man. Your height is about the same as mines right now. Plannin to go lower since I got the raceskid plate on there right now its just the company I bought my jom kit from left out my spanner wrenches so I can't adjust my coils at the moment unless I disassemble strut towers- Josh
1990 325is
Need a shift boot?
