IE3 w/ Billy Sport- Need trim Bump Stop?
  • mccor023
    • Jul 2011
    • 683
    I will be swapping my Vogtland springs for IE Stage 3 in a week or so and wanted to know if anyone recommends trimming the bump-stop in the Billy Sports. Part of the reason I am switching to IE3 is because I frequently bottom out now and would prefer to know if I should trim while everything is apart.
    Thanks.
    I love that people ask stupid questions so I dont have.
  • squidmaster
    • Aug 2011
    • 2666
    plug and play
    • Balleristic31
      • Aug 2009
      • 4198
      You most definitely do NOT have to trim the bump stops on Unmodified ie3s and bilsteins. It's a proven bolt on no issues setup.
      -NICK
      • mccor023
        • Jul 2011
        • 683
        Thanks for the replies. It should make the swap a lot easier if I can just leave the struts alone.
        • Pseudonyms
          • Mar 2012
          • 141
          I have that setup in my car (that was installed by the previous owner) but I've been in and around my suspension a bit and as far as I know you dont need to trim anything. It should just bolt right on.
          • Earendil
            • 1662
            It's bolt up and go. If you're hitting the bump stops something is wrong with the springs or the shocks. Whereby wrong I mean that someone cut a spring or the shocks are shot.
            1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
            2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
            I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
            • mccor023
              • Jul 2011
              • 683
              Cool guys, I havent installed the springs yet was just trying to find out before I did.
                • 37833
                But you can do it, it certainly won't hurt anything to give more travel.
                I did it with mine but I also have 1/2 coil cut and GC Touring camber plates so it's lower.
                Grover Beach, California
                BimmerHeads.com
                • mccor023
                  • Jul 2011
                  • 683
                  So I replaced my old Vogtland springs w the new IE3 springs lowering drop-hats and IE street/ track camber plates. And honestly I was hoping for some drop up front, especially considering IE springs were about an inch shorter.
                  I drove about an hour on the new setup and I was very pleased the ride was much smoother. Now Im hoping the springs might settle a bit.
                  • Earendil
                    • 1662
                    IE drop from stock is a well known thing with lots of pictures posted around here and elsewhere. Are you saying it dropped less than the known amount, or less than you imagined?
                    Don't camber plates raise it back up?
                    • mccor023
                      • Jul 2011
                      • 683
                      I was simple saying I thought I would drop in the front relative to the old Vogtland springs I had in. The camber plates should have lowered it 1/8 inch, and the hats another 1/2 inch.
                      Granted the old springs were old and ?125-175? And IE are 315, the IE were 1-1.5 inches shorter.
                      I recently read that spring settling is a myth, but Im hoping its true.
                      After cruising through pics, per Earendil "it dropped less than the known amount".
                      • Earendil
                        • 1662
                        The other thing that might be happening is the weight of your car. Is it stock, weight, heavy, or light?
                        With a 125 spring, you're going to drop a half inch for every 250lbs* in the car. With the IE 315, you're dropping a half inch for every 630lbs* in the car. That's a huge difference. I know that my car is 200lbs under stock, and as such rides a little bit higher than stock cars with the same H&R race springs.
                        Is your car more fun to drive? Good, then enjoy thy self :D
                        *I'm assuming equal distribution of weight across all four corners, and assuming equal springs on all four corners, after taking into account that the rear springs are half way of a lever and not perfectly comparable. But you get the point.
                        • mccor023
                          • Jul 2011
                          • 683
                          Thanks Earendil, yes the car does ride much better even after only 200 miles. I was planning on giving it another 2-300 miles and taking in for a proper alignment now that I have camber adjustment.
                          Here are the best Before and after Shots I have,
                          Before I was:
                          and Now Im holy reverse rake Batman:
                          I did remove the the spacers in the rear I had before, and will add those back in. IN addition I haven't unloaded the trunk of all my tools, need to...
                          • mulletman
                            • May 2012
                            • 801
                            I am running the H&R Race spring which are similar. Both spring pads in the front, and both with an extra one in the rear make it look more even.
                            • squidmaster
                              • Aug 2011
                              • 2666
                              e90 drop hats help
