are these the right konis?
  • bastianshaw
    • Jan 2007
    • 2210
    89 325is w races? the rears look AWFULLY short
  • butters
    • 1206
    lol. pull them open, they ship compressed.
    • acolella76
      • 2950
      Um what? If you have to 'pull open' your shocks to get them to full length then they are blown.
      -Alex
      • butters
        • 1206
        This does not apply to every damper design. Google around, I'm not an expert so I won't try to lecture on the subject. Suffice it to say that the function of a damper by definition is to resist velocity, not compression.
        I just ordered the same shocks and they came compressed as pictured by the OP.
        OP you might want to search around about the shocks anyway for your own information. In order to adjust the rears, you must extend them fully, poke the rubber bump stop down from the top and pull it off the shaft along with the plastic clip. Then fully compress and rotate, you'll feel the two prongs in the top of the dust cover engage the two holes in the top of the shock body (this would be blocked with the bump stop in there) and then you are twisting the shock body and dust cover "against" each other clockwise/counterclockwise to adjust the level of rebound damping. Righty-tighty for stiff, lefty-loosey for softer.
        If the shocks fought compression like a spring, adjusting like that would be a real PITA.
        • bastianshaw
          • Jan 2007
          • 2210
          DAMN I have never heard of any of this before...I thought they were PNP
          • butters
            • 1206
            They are PNP, but if you would like to take advantage of the adjustable rebound damping level, I thought I'd make the process clearer. Those printed notes are a bit confusing.
            • bastianshaw
              • Jan 2007
              • 2210
              no i mean i thought w how popular they are someone wouldve done a writeup/install guide...I searched and just found 30 threads on koni vs bilstien and races vs sports...SMH
              • M-technik-3
                • 18946
                Koni has switched to gas charged rear on most I was under the impression except in their classic Red's are style all hydraulic system. A part number would really help.
                • Cletonius
                  • 2809
                  This.
                  My konis didn't come with dust covers and they were all about the same length.
                  - Josh
                  1990 325is
                  Need a shift boot?
                  Looking to buy shift boot frames, PM if you have one to sell
                  Here's what happens when you let the internet pick your license plate
                  • bastianshaw
                    • Jan 2007
                    • 2210
                    • M-technik-3
                      • 18946
                      Yes correct ones
