Front end suspension rebuild
  • trashycamaro
    • Feb 2011
    • 70
    Thoughts and opinions welcome. 1988 325 Convertible
    Rebuilding the front suspension next weekend. Parts on hand:
    Used Tokico blue struts/shocks
    2 x New bump stops
    2 x New strut mounts
    2 x New control arms
    2 x New lollipops with oe bushings pre-installed
    Used Vogtland front springs (may install the fronts now and install HR/Eibach vert specific later OR may purchase a full set of vert springs this week for the install)
    2 x New tie rod assemblies
    To be purchased/rented: pickle fork, spring compressor
    Am I missing anything? Is there anything else I should be replacing while everything else is apart? (rotors, pads, bearings, sway bar end links were recently done)
    Also, I may have to replace the starter. Is it any easier to get to with the control arms off?
    TIA
    1991 e31 - Black on Black, 5.0L/6 Speed. Sold
    1990 e30 Cabriolet, 2.5L/auto. Sold
    1999 e39 Touring, 2.8L/auto. Sold
    1988 e30 Cabriolet, 2.5L/5 Speed. Going for retro modern convenience driver.
  • jeffnhiscars
    • Jun 2011
    • 6011
    I would do the sway bar links and bushings and I'd also throw in an e36 rack if time\budget allow.
    Alice the Time Capsule
      If the outer tie rod ends are worn, the inners are two. Replace the entire tie rod and boots. You will also need new lock plates and band clamps.
      • trashycamaro
        • Feb 2011
        • 70
        I actually meant to ask - are tie rods a wear item? Or are you only supposed to replace when bent/broken?
        I bought the outers blindly as they are included in the kits that BavAuto and others have, and I thought they might be a wear item. Turns out I bought a full tie rod assembly - the inners and outers together.
        • trashycamaro
          • Feb 2011
          • 70
          Doing this tomorrow. Got the H&R Cabrio specific springs. Anyone have anything else to chime in?
          Thanks!
          • fuzzysux
            • 247
            just did all of this - replaced every moving part.
            i would recommend to throw the "oe replacement" cab directly into the garbage and just get the OEM e36 control arm bushings.
            i tore apart a couple "cab specific" control arm bushigns.. tried the e36 cabrio bushings since they were supposed to be heavier.. and they were trashed in 3 months - then i just started using centered m3 e36 bushings and life is good.
            • fuzzysux
              • 247
              just saw the date here... how did it go?
              lol
