H&R OE Sport with Yellow Koni
  • plotfi
    • Mar 2012
    • 394
    I am confused which koni shocks to use! Since the H&R OE sport will drop my 1987 325is, to the same hight as e30 M3, I am wondering if I should get yellow konis made for M3.
    Has anyone tried this?
    feedback http://www.r3vlimited.com/board/show...32#post4540332
    1972 2002 Chamonix
    1984 325e Hennarot (M20B31)
    1988 325is Bronzite Time Capsule
  • plotfi
    • Mar 2012
    • 394
    I just got back from Koni:
    325is:
    8641 1021sport compression 500nm, rebound (min)850nm
    80 2522sport - compression 600nm, rebound (min) 950nm
    M3:
    8641 1210sport - compression 700nm, rebound (min) 750nm
    80 2522spa1 - compression 600nm, rebound (min) 950nm
    what do you guys think? which set would be better with H&R OE sport and e90 drop hats?
    1972 2002 Chamonix
    • plotfi
      • Mar 2012
      • 394
      M3 shocks/ struts are also shorter80-2522SP1A.pdf
      80-2522SPORTC.pdf
      8641-1021SPORTA.pdf
      8641-1210SPORT.pdf
      1972 2002 Chamonix
      • plotfi
        • Mar 2012
        • 394
        any help would be appreciated!
        1972 2002 Chamonix
          Use the shocks meant for a 325is and set initial rebound damping to 1/2 turn from full soft.
          • jeffnhiscars
            • Jun 2011
            • 6011
            I was under the impression that to adjust the e30 Koni struts you had to remove them which makes no sense from a practical stand point.
            Alice the Time Capsule
            • DRTSRFR
              • May 2008
              • 1836
              Standard Koni replacements are top adjust in front and compress to adjust in the rear...
              Suspension tips here...
              http://www.r3vlimited.com/board/album.php?albumid=757
              • plotfi
                • Mar 2012
                • 394
                I decided to go with M3 shocks and struts!
                Mark, do you know if there is any harm by using e90 drop hats? it look like, its a little controversial?! I understand I need to use proper washers, but even with that I was wondering if the angle of the top of the hat is the same as e30 hat?
                1972 2002 Chamonix
                • DRTSRFR
                  • May 2008
                  • 1836
                  I have not tried the e90 hats myself, so unfortunately, I don't have a personal answer for that.
                  To my knowledge, the springs will fit, but some have had issues with the hats hitting the upper mount when too few washers were used.
                  Let me go find a spring and I'll confirm...
                  OK, just checked the hat in a spring. fitment is perfect, and there is no angle in the hat.
                  • Victell
                    • 1083
                    Please update thread with how you like the spring/shock combo, after you've had a chance to drive it for a while. Ive been thinking about the exact same setup.
                    • plotfi
                      • Mar 2012
                      • 394
                      Just finished installing everything yesterday. I ended up using H&R sport (50406) with Yellow Konis made for 1987 325is, 86411021sport and 802522sport. I also used all paddings and e90 drop hat. I am very pleased with how it turned out! The front is very nicely lowered. It rides very nice and comfortable way better than stock, not harsh at all!!!
                      The other set up I was thinking about, M3 yellow konis, are too short for for H&R sport or H&R OE sport. They should work great with H&R Race. I am gonna put them on the classified sections soon.
                      I hear some Knocking from front end which was there before redoing the suspension. I think its due to sway bar links. My questions is whether I need to use adjustable links with this set up or not?
                      1972 2002 Chamonix
                      • Cletonius
                        • 2809
                        You don't really ever "need" adjustable links on a street car...
                        You may have to get shorter links, mine were too long so I made some from bits off of 4wheelparts. They came out almost like OE, just an inch shorter.
                        - Josh
                        1990 325is
                        Need a shift boot?
                        Looking to buy shift boot frames, PM if you have one to sell
                        Here's what happens when you let the internet pick your license plate
