Might have ruined my entire power steering
  • Holland
    • Nov 2008
    • 7212
    Originally posted by Bryanlopez325
    Hell yeah just cut that ps belt and I love it,
    Fuck power steering
    I just need that ps delete
    There is a HUGE difference between no belt, a proper delete, and a manual steering rack.
    Originally posted by DEV0 E30
    • Bryanlopez325
      • Jul 2013
      • 115
      What do you mean by a manual steering rack
      • ELVA164
        • 4861
        Some European cars came with a manual steering rack, i.e. no power steering system from the factory. The ratio was ridiculously long (4.45 turns lock-to-lock or something like that) to make up for the lost mechanical advantage.
        • brianf408
          • 51
          That stop leak stuff is pretty nasty goop. I used some in my Land Rover, it had some pretty bad leaks and the stop-leak sealed it up pretty well... but it's also gumming up the pump and the steering box valves. It poured out of the bottle like rubber cement, and is super sticky. I contemplated using some in the e30, but after the experience with my Rover I'm not too sure.
          I'll probably just delete the power steering on the e30. I'd do the same on the Rover, but it's a good deal heavier vehicle, and the steering ratio is just not right for driving without power steering.
          Oh and don't just cut the belt
          • Cosmic Serpent
            • Mar 2012
            • 154
            Im not sure how it works for auto zone, but i worked for advance for a short period of time...
            subsequently you should go back and raise hell about what happened and demand that they give you a new rack. make sure you ask to talk to a manager :D
            Worse case they do nothing, but hey its worth a shot.
            With advance if an employee broke a windscreen or something advance would replace it.
            • DatUtahGuy
              • Jan 2007
              • 3146
              Yeah go ps delete, like stated before, chances are you won't even feel the difference. It's only "tough" when parking but as soon as you go above 5mph it's nice and easy again
              YOUTUBE: AR Perez
              If lucky, the E36 will die peacefully, in its natural habitat, and be given the prestigious honor of donating its parts to an E30
              • mohamed...
                • Oct 2012
                • 577
                I have no ps and i like it a lot more than before. I also just put in a z3m rack
                and you can really feel the difference from the stock rack. I think ps makes
                ruins the feel of driving. Get a real delete, Its only $35 or something like that
                from condor.
                E30 M30 B35 Swap Mounts!
                http://store.garagistic.com/ocart/e3...=5475809a87e04
                • Bryanlopez325
                  • Jul 2013
                  • 115
                  Yeah I've kinda been broke/cheap lately so I'm still on the broken rack w/o ps delete
