Plates for most positive camber
  • jalopi
    • 2370
    Hi guys,
    Trying to figure out who makes camber plates for our cars that would give the most positive camber.
    Reason I ask is that I'm looking at doing a SLR angle kit or something along those lines... problem is that (from what I hear) they put the camber around -6* or so, which is way too extreme for me. I guess I could settle for around -2~-2.5*
    GC camber plates will get 2.5deg, or a bit more, with stock sized springs.
    • Northern
      I like cupcakes & sh!tboxes
      • 5265
      if you called up mark at GC, he could give you some input on what they have to offer. I would recommend staying away from the cheaper/off brand camberplates as well.
      Originally posted by priapism
      Originally posted by shameson
      • lambo
        Captain Scene Points
        • 10953
        iirc GC E28 camber plates more adjustability (I'm not sure in what direction, though) with some modification to the shock tower.
          If using stock diameter springs, the camber limit occurs when the upper spring perch starts rubbing on the strut tower. On the various cars I've worked on (with Spec E30 suspension) that happens at about 2.5deg. Some folks claim to get 3 or 3.5deg, but I've not seen that without bending the strut housings.
          • jalopi
            • 2370
            Hmm... so basically, if I did end up installing an angle kit the most positive my camber could ever get would be around -3.5*? That's still a bit on the extreme side for me... I see why the wisefab kit includes that wacky strut "relocator"
            • Earendil
              • 1662
              That's with stock diameter springs. Most "coilover" aftermarket springs are a smaller diameter.
              1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
              2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
              I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
              • jalopi
                • 2370
                Hm. I think mine are stock diameter (H&R race springs)
                • Earendil
                  • 1662
                  Indeed, those are stock size. Same thing I have :)
                  • jalopi
                    • 2370
                    Ok so does anyone know what the length of the SLR or wisefab control arms are vs stock? Also wondering what the length difference is between them and the (e46) control arms.
                    Not really sure what I want to do here, but now that I'm thinking about it I'm not sure how I feel about those exposed rod ends. It's not the car's my daily or anything, but I sure do drive it more than my truck... not sure how long those exposed rod ends would last and how much it would cost to replace them.
                    • acolella76
                      • 2950
                      Rod ends are reasonably cheap so once they start to have play in them just replace them. Idk which bearings they use so one can only guess as to how long they will last... but if you are concerned about them being exposed you could look into buying some boots. McMaster sells boots I believe, and they have a huge array of rod ends of different capabilities.
                      Also, please let me know if you get those measurements because I've been looking for the same info.
                      -Alex
