Need to differ the ride after a s52 swap
  • matthugie
    • Mar 2004
    • 1810
    Originally posted by Wanganstyle
    Same principle applies to a street car.
    Why did bmw add 38 lbs of sound insulation to the 6 cylinder e30 trunk
    Answer; weight balance.
    I removed it and weighted it on a scale; 38 lbs of stuff in the trunk
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    Are you saying that all street cars should be corner balanced? Do they need to be adjusted based on the commute, if there are more turns in one direction than the other?
    88 325is - S52 powered
    Originally posted by King Arthur
    We'll not risk another frontal assault, that rabbit's dynamite!
    • LJ851
      • 7919
      All cars should be corner balanced ideally. It really makes a difference in handling. You are potentially leaving a lot of grip on the table without it.
      Lorin
      The M30 is God's engine.
      • agent
        Vice Grand Pubaa
        • 7960
        I think that's only if you take a different route on the return trip, since if you go home the same way you came it becomes a moot point.
        Originally posted by kronus
        • matthugie
          • Mar 2004
          • 1810
          I understand that, my point is that for a street only car it doesn't really matter if you're leaving grip on the table. 99.9% of the time the car is being driven well below 80% of the car's potential. Granted you don't want a super twitchy setup that's going to put people in a ditch every time they try to push their car a bit, but there's a lot of room there where the car will be perfectly fine to drive.
          • Wanganstyle
            • 2828
            Street cars need balanced handling more than race cars. Balance is not lap time; bmw balances every single vehicle sold.
            If you loose control at the track you go into the sand/wall/grass and people laugh at you.
            If you loose control on the street you might have just killed a family of kids going to soccer practice.
            Which is a bigger risk?
            Nut behind wheel on track - death to self?
            Or
            Killing a minivan of kids going to soccer practice because r3vtard swap imbalanced spin out??
            R3vtard procedure:
            Buy crap e30
            Don't take care of nice m20 engine
            Kill m20
            Swap in junkyard m50
            Handles Like crap.
            Slam it to look ILL
            Hella frush for cool illest point
            Drive in rain hit puddle spin out crash into minivan headed to soccer practice kill some children and parents.
            • mr2peak
              • 2388
              Sorry, but I'm going to say that the sound deadening is for sound deadening, otherwise they would have just used a different material..
              Drive it hard. Maintain it well.
              A Topless Memorandum
              • Dakotademon7
                • Jan 2014
                • 446
                Or
                R3vtard procedure:
                Buy crap e30
                Kill m20
                Handles Like crap.
                Slam it to look ILL
                Kinda off the deep end there. Did you forget to take your meds ?lol.
                sigpichttp://www.germanaudiospecialties.com/
                1986 325es :early:
                • matthugie
                  • Mar 2004
                  • 1810
                  Or
                  R3vtard procedure:
                  Buy crap e30
                  Kill m20
                  Handles Like crap.
                  Slam it to look ILL
                  So every lowered but not corner balanced car is an imminent threat for every other car on the road and will result in fiery death for everyone. Got it.
                  • LJ851
                    • 7919
                    318is with a lighter engine does not have the heavy sound deadening at all. Coincidence ?
                    Lorin
                    • Wanganstyle
                      • 2828
                      Out of prior owned 40+cars.....
                      Only my e30 had 30+ lbs of tar in the trunk under the mat..
                      My e36m has perhaps 3 lbs of tar? You are welcome to scrape it all off and weigh it; I actually weighed the crap out of the e30 in a garbage bag as it was so heavy I really was curious
                      The r3vtard behind the wheel is the real danger for society
                      • Bearmw
                        • 1323
                        It's pretty well documented why BMW put in the heavy trunk tar as well as why they put the battery back there. BMW engineers really worked hard at making the E30 a good handling car so why not apply their principles to our modifications?
                          • 34844
                          neither does a '91 ix that's 400lbs heavier than the 318is. what's your point? ;)
                          while I agree in principle on getting a car corner balanced, we're talking about a street car. Jesus Christ. maybe get some H&R race and bilsteins and call it a day. next it won't be good enough unless he has some Motons or something with remote resiviors and electronically controlled damper settings with datalogging?
                          • Wanganstyle
                            • 2828
                            Honestly just giving the stance crowd a hard time for amusement.
                            Hai r3v I did a swap and now I'm too hella flush in the front and not hella flush enough in the rear what should I do now cut springs?
                            • matthugie
                              • Mar 2004
                              • 1810
                              How was any of this thread related to the stance crowd? At no point were any of those things mentioned in this thread by anyone other than you. OP asked about stiffer shocks and maybe springs, and all the responses were for H&R, billie sports or Koni's, or a quality coilover setup (GC or KW) if it was going to be a track car. If you want to troll the stance guys there is a stance thread.
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                Wang cracks me up.
                                OP, you have stock touring (blown?) shocks and sport springs. Put HD's in to match and the ride will change dramatically. The H&R sport + HD "or" H&R race + Sport makes good combinations
                                john@m20guru.com
                                Links:
