stupid suspension questions about a 325e
  • a2e30
    • Feb 2014
    • 52
    So this might be a lame and or stupid question, but I just picked up an e30 '86 325e needs some work. But literally got it because it was an (e) and not an (i or is or ix) I have rebuilt 3 other e30's and haven't seen a 325e yet so I thought it'd be cool to have one. But I am a bit lost as to the suspension on the front, whats the difference in suspension shock absorbers to be exact between a 325i or is and a 325e if any? because Pelican Parts seems to think that they are different but they all look the same to me, the only thing that I could think of would be ride stiffness related, and that doesn't matter to me anyway seeing as I lower and race almost every car I buy. Could someone help me out, or tell me that there is infact no difference between suspension (shock absorber tubes). Thanks-- J.
  • FLG
    • Sep 2011
    • 3165
    Yeah, you might have the smaller 45mm strut housings. These can be changed to the larger and more common late style 51mm housings. A quick measurement with a set of calipers will give you your answer.
    Great quick easy measurement pictures in this thread few posts down
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • E30_Pare
      • 7801
      e should be 51mm. Only ix and early 318i (m10) got the 45mm housings
      DREWLIENTE
      1$ PShops PM me
      • TobyB
        • 5293
        There isn't any difference...
        t
        • NoSnowJustIce
          • Jul 2012
          • 169
          No difference.
          • FLG
            • Sep 2011
            • 3165
            I'd check regardless. Who knows what might have been swapped over the past 20+ years. It's 5 min to save you a possible headache.
            Sent from my SCH-I545 using Tapatalk 2
            • Roysneon
              • 4505
              No, iX inserts are same diameter as all late models, I or is. The very early 325e's and early model m10 318s had the smaller struts.
              Originally posted by mbonanni
              I am a pursit now.
              • B Randon
                • 2569
                that's right 86 and down all had the 45, 87 an up 51
                • a2e30
                  • Feb 2014
                  • 52
                  im not trying to stance the car, just replace the shocks, the way the car rides feels like they are the originals. Thanks for the input, I'll go measure them today. But as most of you are saying there is only a noticeable difference between my buddies ix and my car, but the other 325 e30s are very so long as they have the m20. Thanks for all the feed back, Cheers -- J.
                  • reelizmpro
                    • 9558
                    84-85 325e came with 51mm struts from the factory. That was my first car since new. It was only the 84-85 318i and some base model 86-87 325 (no e or i) that came with 45mm according to the Bentley.
                    88 M3 - LACHSSILBER
                    89 M3 - ALPINEWEISS II
                    • TG Goose
                      • Jul 2011
                      • 234
                      My 01/1986 325 had 51mm housings
                      Posted via MotoX
                      ______________________________________
                      1984 LSB 318i - Sold
                      1986 325i - Motor Swapped Track Car Project
                      1995 318ti - Sold
                      1999 540iA - Daily Driver
                      • Gertech
                        • Jul 2013
                        • 180
                        My 02/1986 325e has 51mm housings
                        • F34R
                          sLaughter
                          • 12376
                          Wrong, I had 51 on both my 86 models.
                          Instagram: @BWeissLeather
                          Current cars:
                          ~ '87 325 M30B35 swap
                          ~ '87 535
                          ~ 01 540 Msport 6spd
                          ~ '06 X5 4.8is
                          • efficient
                            • Feb 2012
                            • 3312
                            My 86 has the 51mm if you can wrap a dollar around the strut and overlap the dollar you have the smaller diameter struts but if the dollar doesn't overlap then you have the 51 mm struts
                            btw is breaking the collar nut for the strut cartridge a pain in the ass? Going to attempt it tomorrow to replace my old shock cartridges.
