Evil steering shake at 65mph+, not sure what is the culprit
Rear shocks have 5000, gonna do bushings this month. Think that may be related?
On a different note, the shake is more intense when turning slightly at high speed. The connection to braking I identified earlier doesn't seem to be present anymore. The steering geometry has gone off a bit, the wheel is now turned left slightly when going straight.
I do get a slight synchronous shake in the seat on occasion. I was thinking csb, but it's barely got 2000 on it (as does guibp).
I'm going to see if I can test the inner tie rods this weekend.Comment
There is a little bit of play when shaking wheels at 3 and 9 o'colck, but it is transmitted to the steering wheel, even when locked. The vibration has become more intermittent now, but is more noticeable on high-speed turns. Replaced sway bar bushings yesterday, marginal improvement.Comment
I'm having similar issues, pretty sure it's because I forgot to line up the driveshaft markings.Comment
I took the car out of storage last week and drove it 350 miles on the highway back home. The shake was present between 65-75 mph only, and it was mostly present from the rear (seats), not so much in the wheel anymore. It isn't affected by turns or braking at all, and the car tracks straight. I am hugely confused by this moving vibration.Comment
was trying to chase down a similar prob for yrs.....replaced almost every suspension part. Intermittent vibration, loose steering, u name it. Finally had a PROPER alignment done, and fixed everything. Car was tracking straight before it, but the alignment made ALL the difference. Now the car is tight, no weird vibrations at varying speeds.www.instagram.com/snwmble
#snwmble
Current:
'05 BMW M3 - Silver Grey/Imola Red
'90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
'15 Mini Countryman - Blazing Red/Carbon Black
Past:
'01 Audi Allroad - Light Silver/Platinum Saber Black
'88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
'01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
'90 BMW 325i - Schwarz/Tan sport *Sold*
'89 BMW 325ix - Diamond Schwarz/Black sport *Sold*Comment
It is usually an alignment issue (toe) or wheel balancing/wheel hubcentric issues.2014 Alpine White 335i MSport
(Daily Driver)
Full Mperformance Aero
KW V2 Coilovers
VRSF Catless DownpipesComment
Drove it about 1000kms since taking it out of storage, and the vibration has gotten very specific. It's fine until exactly 104 kph, then vibrates bad until 118 kph. Anything above that is fine. Vibration is gone from the rear, it's only in the wheel now.
The strange thing is that it doesn't shake nearly as much when decelerating through that range.Comment
Hey TSI did you ever figure this out? I have the exact same issues with all new parts. New shocks, shock mounts, springs, brake rotors, brake pads, new tie rods, control arms, m3 control arm bushings, new wheels, new tires, 15mm hubcentric spacers. The problem was there before the spacer install. Wheel bearings aren't new, but they don't make noise and I don't have any other driveability problems.
I've never had my car professionally aligned, I did it with strings. I have not done another alignment since the new wheels.Last edited by EatsHondas; 05-24-2015, 01:30 PM.1989 325i Lachssilber Sedan
5-Speed Swapped
M30B35 Swapped
MegaSquirt MS3X
1987 325i Lachssilber Sedan
260k OEM Automatic Daily Baby
