Check your rack, it might just be the issue. After replacing hubs control arms and steering knuckle I found out this was the culprit. New rack from rack doctors, problem solved.
Evil steering shake at 65mph+, not sure what is the culprit
Solved my problem, I need hubcentric rings. My wheels' bore is 73.1mm in diameter while my hubcentric spacer is same as the stock hub: 57.1mm. After spinning the front wheels, I noticed they were rotating eccentrically, or wobbling up and down. After remounting them a few times, they are as close to perfect as I can get them with the tapered lug studs. The vibration is almost all gone now so the rings should help.1989 325i Lachssilber Sedan
5-Speed Swapped
M30B35 Swapped
MegaSquirt MS3X
1987 325i Lachssilber Sedan
260k OEM Automatic Daily Baby
Originally posted by colombacho View PostCheck your rack, it might just be the issue. After replacing hubs control arms and steering knuckle I found out this was the culprit. New rack from rack doctors, problem solved.
Originally posted by EatsHondas View PostSolved my problem, I need hubcentric rings. My wheels' bore is 73.1mm in diameter while my hubcentric spacer is same as the stock hub: 57.1mm. After spinning the front wheels, I noticed they were rotating eccentrically, or wobbling up and down. After remounting them a few times, they are as close to perfect as I can get them with the tapered lug studs. The vibration is almost all gone now so the rings should help.
