Rear trailing arm tethers / limiting straps?
  • JGood
    • Jan 2004
    • 7959
    Is anyone using a tether or limiting strap for their rear trailing arms? I have short rear coilover springs that fall out of place every time I jack the car up. They usually pop back in place with a loud, painful thud when I lower the car, but if not, I have to spend 10 minutes trying to get the car just low enough that I can push the spring in place with a long prybar, and hope that it stays there until I crawl back out. Complete PITA.
    I'm thinking about just getting a braided cable or strap of some sort, attach it to the shock, and make another mount on the body somewhere.
    Just wondering if anyone has found an easy/cheap way of getting this done before I go experimenting and wasting money.
    Thanks
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
  • JGood
    • Jan 2004
    • 7959
    Found this, looks easy and cheap enough!
    • ravenlord89
      • May 2012
      • 111
      Most offroaders with long travel just use seat belt webbing or some sort of equivalent. I am sure if it works for dakar it will function fine on your car.
      Most of the setups I have seen are a welded rod/ bolt/ mount point on the frame and then it mounts to the axel somewhere.
      ^^^ or that... that would work too. (I would still use fabric myself... because salt)
      1990 BMW 325is 5spd Black
      2005 Subaru Impreza 5spd
      2015 Yamaha FZ-07
      • SkiFree
        • Jun 2011
        • 2766
        It's standard practice on our racecars.
        Like you said just a plain braided strap. You could use the shock mounting stud at the bottom, but it is easier here to dig out an L-shaped laser-cut piece of steel and bolt it to the bottom spring-mount sheet metal (probably substitute some cheap angle-steel to do the same thing).
        ADAMS Autosport
        • Axxe
          • Aug 2004
          • 3355
          Or you can have a shock that has proper range of travel for your spring and not have to worry about having a mile and a half of droop. My E36 with TRM coilovers looks like stock ride height when it's on the hoist (minimal droop because shock is in the right range of motion).
          Keep it slideways!!
          • JGood
            • Jan 2004
            • 7959
            Buying a new set of shocks to replace my almost-new Bilstein sports which are great for me in every way except for the slightly excessive, and non-performance impacting droop, would be a bit wasteful in comparison to spending $10 on a strap... Haha
            • acolella76
              • 2950
              Psssh... just put the spring over the shock and call it good ;)
              -Alex
              • blue plates
                • Feb 2014
                • 580
                What a tool.
                Originally posted by IRON-E
                Yeah, you're definitely a vw
                • mr2peak
                  • 2388
                  This is why Bilstein has 2 different shocks for the E30. Get the right one the first time.
                  Drive it hard. Maintain it well.
                  A Topless Memorandum
                  • acolella76
                    • 2950
                    FWIW, it would be more helpful if you guys listed part numbers or a vendor that carries the shorter shocks. I know I have never seen a shortened off-the-shelf Bilstein Sport for an E30, I'm sure I'm not alone, so why not post more info?
                    -Alex
                    • Roysneon
                      • 4505
                      Letting people know you know something they don't helps you feel more superior than actually helping someone out by telling them what you know.
                      Originally posted by mbonanni
                      I am a pursit now.
                      • SkiFree
                        • Jun 2011
                        • 2766
                        Especially when you might not actually know as much as you think. It's all good though, there are certain instances (with a properly setup suspension) where a tether is a nice touch.
                        ADAMS Autosport
                        • JGood
                          • Jan 2004
                          • 7959
                          Done. Easy and cheap enough, and now I have a tie down point as well. The tie down hole should probably be slightly larger, it's only about 1-1/8".
                          • LJ851
                            • 7918
                            So, when you go to full extension over a hill the cable unscrews your shock bolt ?
                            Lorin
                            The M30 is God's engine.
                            • dsm2002
                              • 193
                              Only on one side, of course. The other side it would tighten.
                              JGood, you could loosen and rotate the tie down bracket so the holes line up with the pull of the cable.
                              You may also want to consider a short piece of steel bent about 45 degrees or so with two holes, one for the rear shock bolt and one for a crimped on clevis and pin for easy removal.
