Lol, valid point. But, that cable is about 1" from the shock bolt, and not horizontal either. So if that bolt is at 60 ft lbs, it would take what, 700+lbs of weight on the rear trailing arm to spin the bolt loose? The load rating of the cable is 340lbs, with those clamps probably more like 250-300 lbs. I have the cable adjusted so that the spring is actually loose in the perches, so there is only the weight of the trailing arm on it, not the spring pressure. In order to get that thing tight while driving, I'd basically have to ramp the car, and even then, I doubt the trailing arm will be shooting down with 700+lbs of force.
That said, it is a valid point, and I'll probably do something about it.
i have no idea what i am doing with my life
