Rear shocks in 'bind' from IE solid shock mount?
  • Frog
    • Jun 2010
    • 980
    So I have installed rear shocks before but never solid shock mounts.
    I installed solid IE shock mounts on my e30 and when I bolted the bottom of the shock, I had to force the shock to lineup with the trailing arm.
    I know it will unbind some once I drop the car off, but is this bad or normal?
    Is it ok to leave it like this while the car is up, or should I unbolt the bottom of the shock every time?
    Winner winner chicken dinner?
    My Seller Feedback Thread
  • DRTSRFR
    • May 2008
    • 1836
    Absolutely normal for bushing style mounts. You won't have any problems.
    Suspension tips here...
    http://www.r3vlimited.com/board/album.php?albumid=757
    • E30NJ
      • Aug 2013
      • 921
      Yep like GCMARK said, thats 100% normal. Its basically the same on most bimmers I believe up to E46era had the same style
      • LJ851
        • 7919
        Great drawing!
        Lorin
        The M30 is God's engine.
        • Northern
          I like cupcakes & sh!tboxes
          • 5284
          Ran IE RSMs for 3 years or more now, never experienced an issue once it was bolted up.
          Only removed them for GC RSMs so it would match the front
          Originally posted by priapism
          Originally posted by shameson
          • Liquidity
            • May 2014
            • 395
            WHen the suspension compresses it will swing back into line. The wheel swings forward as the arm drops. Don't forget you can't tighten the bottom bolt until the suspension is compressed with the car at ride height. The rubber bushing in the shock will twist and tear if you tighten it with the car in the air.
            • Frog
              • Jun 2010
              • 980
              Never read that before.. So I finger tighten it and then torque once it is on the ground?
              • Liquidity
                • May 2014
                • 395
                As long as the sleeve can spin freely until the car is at ride height.
