How to adjust your koni yellows for dummies.
  • Mr. Burns
    • Aug 2011
    • 3516
    Have you shock fully compressed.
    Manually pull up the shock and identify the plastic ring.
    Remove the plastic ring
    With a wire coat hanger, thin welding rod or similar, poke through the access holes to loosen the bumpstop within the assembly.
    Remove the rubber bumpstop
    Compress the shock once again. Turn and you will feel a "click" or a "notched" feeling.
    This means the adjuster valve has been activated.
    Twist the assembly to your desired rebound stiffness. For me, it us aproximately 5.25 turns from soft to hard.
    Once your desired stiffness is achieved pull up about 1", as this will lock the adjustment in place.
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • Roysneon
    • 4505
    Dear God why can't it be as easy as the fronts? I'm now in much less of a hurry to get rear Konis to match my fronts. I'm sure the Bilsteins in the rear will be fine for now.
    Originally posted by mbonanni
    I am a pursit now.
    • digger
      • Nov 2005
      • 6197
      top adjustable, just turn the knob
      • Mr. Burns
        • Aug 2011
        • 3516
        oh my koni fronts are just like the rears.
        when ordering your Koni's....MAKE SURE you get the externally adjustable ones...
        • Roysneon
          • 4505
          OH ok good haha I was concerned.
          I am a pursit now.
          • jrobie79
            • Mar 2006
            • 2526
            whats the p/n for the top adjusting ones?
            1991 318i ---- 308K - retired
            • ELVA164
              • 4861
              I also wish my rears were externally adjustable like the fronts. I wanted to add a quarter-turn or so to them last time I was under there, but couldn't feel the click and just left them as-was.
              • acolella76
                • 2950
                And I thought my adjuster being at the TA was a pain. LOL. So you have to fully compress those shocks to adjust them?
                -Alex
                • LJ851
                  • 7919
                  Yes, after you remove the bumpstop. This makes it so you actually have to remove the entire shock from the car to adjust it. That being said, i can ajust both of my rear konis in 10 minutes flat.
                  Lorin
                  The M30 is God's engine.
                  • ELVA164
                    • 4861
                    Not really true, though probably preferable on a street car. I adjusted the old Konis on the Cortina with the threaded ends still attached without much trouble. Externally adjustable Spax now though!
                    • ian e30 318is
                      • Mar 2007
                      • 1809
                      This took me about an hour to figure out the first time! Good information for others.
                      1991 LS1 Swapped 318is
                      Instagram:
                      https://instagram.com/saltybeast/
                      LS Build Thread:
                      https://www.r3vlimited.com/board/for...s-e30-ls1-swap
