Mounting Koni's- Strut Bushing
  • Klug
    • Sep 2011
    • 804
    On the bottom bushing, I have a part of the metal sleeve that sticks out more on one side than the other. Which side gets mounted to the car? I have them so the stickers are facing out, its like this on both sides.
    555Garage - Kingston, PA
    '13 BMW e70 X5 35d
    '95 BMW e34 525i
    '92 BMW e30 325i S52 Vert (Quade the Vert)
    '92 Range Rover Classic
    '90 Range Rover Classic
    '89 BMW e30 325i Coupe (The DIRTY30)
    '81 VW MK1 Rabbit Caddy Diesel
    '76 Honda CB550K Cafe/Brat
    '67 Pontiac LeMans
    '24 Model T Depot Hack
    ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
    The extended portion of the sleeve should be against the trailing arm. Which looks to be what you have done.
    • Klug
      • Sep 2011
      • 804
      Perfect, thanks!
      '13 BMW e70 X5 35d
      '95 BMW e34 525i
      '67 Pontiac LeMans
      • Mr. Burns
        • Aug 2011
        • 3516
        holy $hit I just mounted my rear koni struts yesterday and completely forgot to sneak that washer on...drove to work today to with it...
        Originally posted by flyboyx
        i have watched my dog lick himself off a few times
        • jeffnhiscars
          • Jun 2011
          • 6011
          If I swap my Bilstein sports for konis can I reuse all my existing mount and hardware or do I need to change anything that doesn't come with the konis ?
          I thought I read that something in not compatible.
          Alice the Time Capsule
          • jrobie79
            • Mar 2006
            • 2526
            in the front the bilstein use a proprietary gland nut...the koni's use a stocker (and stock bump stop/dust sleeve)
            1991 318i ---- 308K - retired
            • jeffnhiscars
              • Jun 2011
              • 6011
              I don't recall ever seeing a stock bump stop but then I suppose they get removed sometime in the first 20 years. Are they a must on a mildly lowered car ?
              • jrobie79
                • Mar 2006
                • 2526
                no idea, I'm putting them on my car (H&R race springs) because the roads in Massachusetts are fucking awful
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  I did see them on realoem and it said mtech or sport suspension so it sounds optional depending on how lowered you are.
