R&R struts easier than book method?
  • funcrew
    • Jun 2007
    • 1223
    The only struts I ever did were E36 ones in an E30. In that case I didn't have to separate any ball joints or tie rod ends like the E30 write-ups all describe. Now I'm faced with doing the same thing on a real E30 front end. Do you fellows find that all that commotion is really necessary, or can the strut be finessed out taking fewer joints apart?
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
    • 37833
    I always unbolt caiper from bracket, unbolt swaybar at control arm, unbolt tierod at spindle and unbolt control arm at spindle. Really no other way to do it besides removing the whole housing. Once it's out I use spring compressors and a electric impact for the top strut nut.
    Grover Beach, California
    BimmerHeads.com
    • funcrew
      • Jun 2007
      • 1223
      Matt, what do you mean "besides removing the whole housing?" Wouldn't that be easier? Edit: Now I see that the E30 strut housing doesn't unbolt from the spindle like an E36 does. Thus my confusion.
      -Dr. Paul Forrester
      • Northern
        I like cupcakes & sh!tboxes
        • 5265
        Not sure what springs you have. With stock springs this may be more difficult or impossible to do...
        A: Droop suspension, (If your springs are still compressed use a spring compressor until they're loose) remove strut nut, remove strut mount, loosen/remove gland nut and slide strut insert out through the shock tower hole.
        B: Same as above, except remove swaybar endlink, remove caliper and support it, then compress the strut slightly and lean the strut housing out of the wheel well before loosening gland nut.
        I've done this many times with H&R Race, Ground Control, and German Engineering setups.
        Originally posted by priapism
        Originally posted by shameson
        • funcrew
          • Jun 2007
          • 1223
          I'm using tallish H&R OE Sports, not much shorter than stock. I went ahead and removed the struts; it wasn't as bad as I expected. Might use your method next time I'm working on a short spring setup.
          -Dr. Paul Forrester
