my face, is sad :( (gc coil question)
  • Best_name_available
    • Jul 2014
    • 479
    so after much anticipation I called GC to place my order, and was shot down promptly. When I said I wanted a stiff low setup for a DD and auto x we settled on 400/600 but when I said I wanted to run my bilstein sports he said I would need the GC koni shocks and that was the end of it. I'm a bit confused as it seems that lots of people are running the GC conversion with billys so what's the deal should I go through with it or not?
    Originally posted by Vokuhila
    I laughed, and then I serioused
    • 37833
    Call back and talk to Mark. Maybe he will be more helpful? You can definitely run Bilstein Sports.
    Grover Beach, California
    BimmerHeads.com
    • nrubenstein
      • 3148
      If you want to be *low* you want a shortened strut setup.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • Roysneon
        • 4505
        This. You will barely be able to tuck tire in the front with Bilstein Sports. If you're really looking to do this on the cheap, get the GC conversion kit, buy Koni SA for a 325ix, then section about 2" from your housings, weld on the new perch from GC. You will need a spacer in the bottom of the housing to make up the difference between the 2" you cut and the 4" shorter that the iX strut is.
        I just finished installing this same setup and it's the best I've had by far. I am now lower with the short Konis/chopped housings with my German Engineering coils cranked all the way up as I was with the full length Bilsteins with the coils all the way down.
        Originally posted by mbonanni
        I am a pursit now.
        • Eric
          • 5142
          I had GC on bilsteins on my old E30 M3 and the ride sucked due to bouncing off the bump stops constantly. GC is right about the Koni's, it's way better.
          • Roysneon
            • 4505
            The last couple pages of my thread here are very pertinent to this discussion
            I am a pursit now.
              • 34839
              Ground Control is right. You need konis, Bilsteins are going to be too long.
              • Andy.B
                • Sep 2011
                • 1650
                This.
                Section the housings and run shorter inserts to maintain suspension travel. Any local fab/welding shop should be able to do it for you for cheap (It cost me $50 to get spacers fabbed up and both housings sectioned 1"). My front adjusters are all the way up, and the tops of the tires are flush with the fenders. If you are looking for a cheaper option than the Koni's, check out the Camaro shock thread for info on fitting 2nd gen mr2 strut inserts in the e30.
                  • Jul 2014
                  • 479
                  Wait so if run koni ix in the front with shortened struts can I still run the Billy sports in the back and get low? I ask this because I already have billys. Is the GC kit better then the GE kit other than choosing your rates?
                  • nrubenstein
                    • 3148
                    You can also run iX Bilsteins in shortened struts.
                      • 34839
                      the ride will still suck
                      don't bother messing with ix bilsteins.
                        • Jul 2014
                        • 479
                        notably noted my friend, notably noted.
                        so how about my installed rwd bilstein sports in the rear are they ok to go low?
                        • RedReplicant
                          • Oct 2009
                          • 270
                          Just try it if you've already got them. Worst case is you don't like how it rides so you replace them with something else and throw 'em in the classifieds.
                          91 318is - Gone
                          16 VW GTI
                          07 Aprilia Tuono
                            • 34839
                            I'd run the same shock all the way around but you may as well try it.
                              • Jul 2014
                              • 479
                              Yea I'll try it, guess it should be fine since everyone is saying the billys are stiffer
