I just bought some bushings for my lower control arm and I'm not sure if there is an easy way to remove the bushing from the bracket to install the new one. Any ideas will be helpful.
Control arm bushing removal
Tags: None
Need minimum of a 20 ton press. Good luck doing it at home. That's why people pay extra and get them pressed in lollipops. Take them to a shop and see if they will do it for you. Or else buy a 20 ton press. I got one from harbor freight for 175Comment
12ton is more than adequate for control arm bushings and ball joints, I have done hundreds of them on mine.
For the bushings, you can also use a large bench vice to press them in, and can get them out with a punch as mentioned, or cut a slice in the metal sleeve and they will come right out.Comment
If you got a press you just press the old one out with the new one. I always thought it was 20 ton for ball joints.Comment
The last time I did this I could press the bushings into the lollipop, but could get the control arm back through the bushing. What a pain.
Any tips for getting this part of it done?
(I ended up going with poly bushings just to get it done, but I'm not to thrilled with them)
DanComment
Soap and a dead blow hammer works great.Comment
Well I don't have a vise or anything but I was thinking that many a large c-clamp might do the trick? Cutting a piece of the sleeve will make it pop right out?12ton is more than adequate for control arm bushings and ball joints, I have done hundreds of them on mine.
Believe he's talking about cutting the lollipop. A c clamp won't work you need something to hold it in place like a bench vice or tri pod vice while you wack away at it.Comment
