H&R Race/IE3 - Front Camber
  • Digitalwave
    is a poseur
    • 6299
    What should I expect for static front camber with H&R Race or IE3 springs? Right now my car is on Racing Dynamics springs and it's clear that there is barely any camber in the front. The car is being setup for autocross, so I'm deciding if it's going to be necessary to order camber plates.
    RISING EDGE
    For best performance you'll want camber plates. I'd crank in at least 2.5 deg of camber.
    • Digitalwave
      is a poseur
      • 6299
      Yeah... that's what I figured. Are the IE SpecE30 plates a viable option for $100-150 less than GC and Vorshlag?
      RISING EDGE
      • Cabriolet
        • 9620
        yes it will be. you wont have enough front camber to match the rears. lowered im at like -1.5 degrees and you will need -3 to really make the car effective.
        Much wow
        I hate 4 doors
        • Zreberlcoe
          • 1555
          IE camber plates aren't very good.
          1991 325i Calypso Coupe
          Like Grandfather, Like Father, Like Son
          BMW
          • Digitalwave
            is a poseur
            • 6299
            Care to elaborate?
            RISING EDGE
            • Cabriolet
              • 9620
              i know several people using them for more than 5 years. they track and autox their cars. 0 issues.
              Much wow
              I hate 4 doors
              • SkiFree
                • Jun 2011
                • 2766
                Yep, can't please everyone I guess.
                OP you may want to even consider using a simple set of fixed camber plates, if you want to keep a softer street feel (since you retain the stock upper strut bearing and all its rubber isolation). But there are plenty of people running the IE Spec plates.
                ADAMS Autosport
                • JRKOUPE
                  • Dec 2004
                  • 3159
                  HR race here...
                  I run a fixed camber plt, and I have neg 3.3 on both sides......works very well on track..I need more tho for serious track work.
