Dropped on gc Springs. Bouncy.
  • brahbarian
    • Mar 2012
    • 153
    I attribute it to the soft front Springs. But just curious on what going on.
    First of my rates are f-300 and r-600. I just bought f-500 to replace the 300. I didn't put the adjusters on the rear (85 early arches). It's not terrible but it feels a bit bouncy. Just curious what would cause this. Bilstein sports all around.
  • dewme5
    • Mar 2014
    • 165
    Shocks control motion.
    • AndrewBird
      The Mad Scientist
      • 11898
      ^^^What he said.
      Shocks/struts are what prevent bounce, not springs. Are your struts new?
      • kronus
        • Apr 2008
        • 13032
        did you drop it so low that the shocks are on internal bumpstops?
        cars beep boop
        • RedReplicant
          • Oct 2009
          • 270
          It'll be more bouncy with your new springs up front.
          91 318is - Gone
          16 VW GTI
          07 Aprilia Tuono
          • ak-
            • 12422
            Raise the car all the way up and go for a ride, then report back to us how it feels.
            That'll tell us a lot.
            1991 325iS turbo
            • DER E30
              • Sep 2013
              • 2349
              Shocks, my spring rates are F500 and R500 and mine is beautiful.
              -Christian
              • brahbarian
                • Mar 2012
                • 153
                Great input. I pulled the rears from a junkyard. I had only done the fronts and rode around on that for 3 months. When I finally got around the doing the rear it got all bouncy. I'll try camaro agx on the rears next.
                I'll turn up the fronts once I go to install the new Springs. Btw the fronts are turned about half way. I didn't cut the stock spring perch.
                • DRTSRFR
                  • May 2008
                  • 1836
                  Post a pic of your ride height. You are probably sitting on, or very close to, the bumpstops.
                  Suspension tips here...
                  http://www.r3vlimited.com/board/album.php?albumid=757
                  • brahbarian
                    • Mar 2012
                    • 153
                    Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
                    I'll try and get better pics. Wheels are oversized. I'll get numbers.
                    • DRTSRFR
                      • May 2008
                      • 1836
                      Yup, your bouncing off of the stops in front. The 300 pound springs will contribute to that. 375 or 400s up front are the best choice when paired with billys.
                      Trim the bumpstops. The ride will improve quite a bit.
                      • brahbarian
                        • Mar 2012
                        • 153
                        Okay. I have 500 Coming in. I'll report back. How about the rears you think? Should I go camaro shocks or stay Billy sports?
                        • DRTSRFR
                          • May 2008
                          • 1836
                          Billys will handle 600-650 in the rear.
                          AGXs will add adjust-ability at the expense of ride comfort at higher settings, as the compression valving ramps up with rebound quite aggressively.
                          • acolella76
                            • 2950
                            The highest rate I would use on a Camaro AGX is 450, maybe 500 if you are bold. The adjuster doesn't do a whole lot for high-speed (only about 25lbs of adjustment) but adds a good bit of low-speed rebound. Doesn't really do anything for compression.
                            edit: here's the graph of a Camaro KYB AGX
                            -Alex
