rear wheel jumping around when recovering traction: Why?
  • MatRacer
    • 562
    On my S50 E30, when I loose traction (easy since 195 tires) and recover it, the rear wheels are jumping /bouncing around. Its not always doing it, but when it does, its very annoying.
    I have 500lb in rate spring with bilstein sport shock. Can it just be a tired shock? What else could it be?
    E30 now S52
    2008 Suburban LTZ (Family and TT hauler)
    325xiT (Sold)
  • JGood
    • Jan 2004
    • 7959
    That's called wheel hop. While it could be caused by failing suspension components, it's more likely normal. Here's two sources of info on it:
    Every part of my suspension is brand new, and I get wheel hop sometimes. It just happens. Certain power/weight/traction combo's experience it, others don't.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • haggardfab
      • Sep 2011
      • 283
      adjustable dampning shocks can help fine tune the suspension to keep the wheels planted
      IG: haggardfab
      • efficient
        • Feb 2012
        • 3312
        I thought I was having a problem with my rear passenger side spring binding and it ended up being that my CSB was flopping around and causing vibrations only when I smashed from a dig.
        • MatRacer
          • 562
          Thanks for the Info! sorry for my French translation! haha!
          E30 now S52
          325xiT (Sold)
          • abit
            • Jul 2011
            • 423
            I belive everybody had/ have this problem, maybe someone could give some advices
            recently changer rear suspension setup,
            I had previously bilstein b8's with some aftermarket -40 lowering springs, and It started to do wheel hop when hard acceleratin in wet conditions but not always.
            Now I have 120mm long, 120nm stiff springs and 80-2522sport ''adjustable'' Koni's (as I remember rebound is on 3/4 ''stiff'')
            And now it seem like its starting to do wheelhop more often, but still only on wet. now rear is stiffer and that wheel hop feels hard and painful :D
            maybe try to adjust shocks softer or full hard? then wich way to try first?
            other suggestions?
            http://instagram.com/mundieriss
            my 88' m20b30 HERE!
            • DRTSRFR
              • May 2008
              • 1836
              90% of wheelhop is caused by soft or failing subframe/control arm bushings.
              An LSD rear dif will often make the problem worse, as both rear wheels are hunting for traction.
              Suspension tips here...
              http://www.r3vlimited.com/board/album.php?albumid=757
              • e30_325es
                • 1249
                Be careful with wheel hop, you can break shit that way, trust me. I've lost a diff and 2 axles (separate occasions) due to it.
