Paging GE Coilover owners
  • HennaE30
    • Apr 2014
    • 1965
    So I'm looking at getting a set of GE coils. How exactly do they go together? It says that you dont have to weld your struts at all, but how do the adjusters mount? Do they screw into the threads at the top of the strut (where the shock insert lock nut goes)? Also would you recommend cutting the OEM spring perches? How difficult is it to adjust with the OEM perches?
    Originally posted by flyboyx
    how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
    Originally posted by Northern
    beer is my new liver cleanse.
    Henna - '84 Hennarot 325e
    Lola - '89 Schwarz 325is - being saved
    Christine - '88 Schwarz 325is - Spec E30 Racecar
    '01 White F150 Lariat 4x4 Supercrew - Daily
    Dad's '05 Interlagosblau M3
  • Mr. Tasty
    • Jul 2011
    • 3421
    The front adjusters have a rubber band of sort, that goes between the housing and the adjuster. It causes a friction based fit.
    The perch should be cut (although generally not NEEDED) to allow easier adjustment.
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • HennaE30
      • Apr 2014
      • 1965
      So do they have to be pressed on? or are they loose enough to just be hand pressed?
      • Mr. Tasty
        • Jul 2011
        • 3421
        I used a rubber mallet. They won't lift up.
        (Daily Driver)
        KW V2 Coilovers
        • HennaE30
          • Apr 2014
          • 1965
          Ok cool man. Any idea on a line for a set? Einstein said he didn't have any sets currently.
          • Northern
            I like cupcakes & sh!tboxes
            • 5270
            Watch the FS section like a hawk. I picked up my set for $250 a few weeks after the group buy ended.
            I would definitely recommend cutting the OEM perch off except for the weld. The sleeve sits nicely on the weld left behind. If I were to cut my housings, I would do it nicer.
            PS. They feel great with Konis and GC race plates (just make sure you get the right diameter upper perch with the plates)
            Originally posted by priapism
            Originally posted by shameson
            • HennaE30
              • Apr 2014
              • 1965
              If I can find a set I'm going to run them with Konis and GC hybrid plates. But if I can't find some, I'll probably end up getting H&R Races
              • KIRIEIW
                • Dec 2012
                • 3385
                I wish I had a better picture for you, but this is the best I have.
                SO that's a picture of my GC set up for reference. The problem with not welding a new perch is simple, the adjuster nut (yellow piece in pic the spring rests on) will make contact with the stock spring perch. That means you would only be able to adjust your coilovers less then HALF of how low they should go. If you cut the spring perch and welded on a skinny one, the yellow adjuster wont hit anything, and you can go all the way down to the bottom threads.
                Now, my little review. I did install the coils like you see in the pic, without welding. The lowest setting using that method (no welding) actually raised my car higher then my Eibach Pro Springs I had in originally. A week later I took everything out and welded in a new perch. This is how it is now,
                As you can see the yellow adjuster can go all the way down with out hitting the stock perch. Again, leaving the stock perch will limit your adjustability, and possibly raise your car higher then It was originally.
                1992 e34 Touring- S50 Swap
                1992 325i-S50 Swap (SOLD)
                1991
                • HennaE30
                  • Apr 2014
                  • 1965
                  How all are your springs? Also do u have a pic of it before and after cutting the perch? I've thought about grabbing a set of GCs if I can't get GEs
                  • KIRIEIW
                    • Dec 2012
                    • 3385
                    Springs are very comfortable! Highly recommend them. I went with 375 front 475 rear. Sadly, I don't have a before and after, but for reference on my stock tire size 15 inch basket weaves, I had a 3 finger (just measured my fingers lol, 2 inch gap) between the fender and tire before cutting the stock perch off. And again, that was the absolute lowest I could adjust it down before cutting the stock perch off. Keep in mind this isn't shorting the housing, just cutting the perch off.
                    Here is the height I'm at now, as you can see in the previous pic, I can still go a tad bit lower.
                    image by kirieiw, on Flickr
                    1991
                    • HennaE30
                      • Apr 2014
                      • 1965
                      I meant how tall are your springs, sorry for the typo. And that fitment would be perfect, maybe a little lower. (I'm on 17x7.5 215/40).
                      • KIRIEIW
                        • Dec 2012
                        • 3385
                        6 inch's front, 5 1/2 rear
                        1991
                        • HennaE30
                          • Apr 2014
                          • 1965
                          Yea that's what I thought.. If I went with GEs it would be 5in springs. 450f 650r with Koni Yellows most likely
                          • KIRIEIW
                            • Dec 2012
                            • 3385
                            Because I don't track, I went with softer springs, and I'm happy I made the choice. Very comfortable. Also for reference, I have a little under 4 inchs of oil pan clearance at that height. Oh and I forgot to respond to "maybe a little lower", no way If you don't weld.
                            1991
