Steering rack swap for airbag cars...
  • M42Technik
    • 9781
    #31
    Originally posted by Brew
    I didn't mess with the steering rack spline at all. I did "clearance" the u-joint before I installed everything, but when I bolted the everything up it turned out I didn't have to. The only modifications I made were to the firewall.
    FACK you tell me this now. I had a new '95 M3 steering rack in my grasp for $320. NEW.
    Reminiscing...
    • dude8383
      • Jan 2005
      • 10387
      #32
      where can i find a good used 95 M3 rack?
      • 1991 318is
        • Dec 2005
        • 786
        #33
        Rack info.
        Anybody know the turns lock to lock on a 1996 328i rack?
        • fazio8118
          • Mar 2006
          • 35
          #34
          3.2 im pretty sure
          SEA E30Kr3w
          • So Live
            • 2512
            #35
            I know theres a thread on e30tech with all the possible racks and their turns lock to lock. If anyone wants to search go for it. Im glad a few of you have done this cause my rack is starting to puke.
            -Chris
            • Jean
              • 18228
              #36
              Bump, i know there is a lot of talk on this thread about a swap into airbag equipped car but if it's not an air bag car will the firewall need to modified to fit an e36 rack still ?
              • mikeltang
                • Feb 2006
                • 212
                #37
                from what ive read the firewall only needs to be modified for airbag cars. so the e36 rack should fit without any modification to the firewall. heres a write-up i found: http://www.r3vlimited.com/board/showthread.php?t=66247
                hope this helps
                - Mike
                AWII 1991 318is - Sold
                Schwarz 1988 325is - Sold
                Schwarz 1991 325i - Driven
                • dude8383
                  • Jan 2005
                  • 10387
                  #38
                  E36 lock plates, put them in last night.
                  sorry to bring this back from the dead...but i was looking over this cause i was helping a friend find info about the airbag racks.
                  anyways what are these e36 lock plates that you're referring to?
                  • Brew
                    • 3060
                    #39
                    They lock the inner tie rod to the rack to keep them from loosening up.
                    '91 318is
                    • dude8383
                      • Jan 2005
                      • 10387
                      #40
                      where can i find something like this?
                      turner?
                      • PeaveyBassist
                        • Sep 2004
                        • 3511
                        #41
                        turner?
                        BMAparts.com They are only like... $.70 a piece or something.
                        Will
                        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                        Welcome e30 (brilliantrot '90 325is) 12/23/06
                        DaveCN = Old Man
                        My signature picture was taken by ME! Not by anyone else!
                        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                        • 1990m3
                          • 1180
                          #42
                          or you can find them at your dealership. If you are a BMWCCA member most dealerships give great discounts. I get 20%!
                          • hoveringuy
                            • Dec 2005
                            • 2752
                            #43
                            I put a 3.2 turn rack out of a 328 into my airbag-equipped is. It was easier than I expected it to be and I would say it is almost a drop-in replacement. Yes, I did need to dremel about 1/4 inch from the firewall but even the 3.2 turn rack has been a HUGE improvement over the original 3.5 unit. The stock lines are also perfect with a small amount of bending, no need for e-36 lines! :grin:
                            Hoveringuy
                            • dude8383
                              • Jan 2005
                              • 10387
                              #44
                              Hoveringuy
                              the 3.5 unit? were you using an e30 m3 rack? stock e30 racks are 4.0 lock to lock.
                              • whelton70
                                • Mar 2004
                                • 115
                                #45
                                hate to bring this back from the dead but couldn't you just use a non-airbag e30 steering column instead of the modify on the firewall? or is it just that the air bag cars have a completely different angle setup from the factory that has to be changed to work with the e36 rack?
