Tips on re-threading steering shaft?
  • phenryiv1
    • Jul 2009
    • 3246
    So this happened...
    I took the car for an alignment after camber plates and an e36 rack swap install. I got it back and the turn signal cancel was malfunctioning worse now than before the alignment so I pulled the wheel to check the cancel nub. The nut (brand new) had compromised threads and the shaft itself was a mess. There were extra washers between the hub and the nut.
    Upon examination of the old Momo hub versus the new one I can see that the hub has an issue with the casting of the cancel nub. I don't know if this caused the turn signal issues but my stalk will cancel from the right but not the left.
    Alignment shop swears that they did not pull the wheel but I know damn well that when I installed the Momo wheel and the new steering nut that I used one washer- not 3. I found 2 washers in addition to the OEM one that I installed.
    Looks like I will be re-threading the shaft from an M14x1.5 to an M12x1.5. Any tips before I undertake it?
    Fun.
    Patrick Henry
  • LJ851
    • 7918
    Get another shaft. The steering column is not a place for less than 100% repairs.
    Lorin
    The M30 is God's engine.
    • phenryiv1
      • Jul 2009
      • 3246
      The shaft is cheap- $41. I will be replacing it. In the meantime I need the car to drive. Not my daily but it has to go to the body shop Wednesday. I had to wait 5 weeks for the appointment and if I miss it I don't have another month to wait for my punch list to be finished.
      Several other manufacturers (MB, Porsche) use an M12x1.5 nut for the steering shaft so it isn't structurally unsound but I do want to properly repair it ASAP. In the meantime I need the car to move.
      Patrick Henry
      • LJ851
        • 7918
        Ok, how about rethreading to 1/2 inch (approx 13mm) instead of taking it down 2mm?
        Lorin
        • phenryiv1
          • Jul 2009
          • 3246
          Good point...
          I figured that the threading constituted ~1mm (.5 per side of the shaft itself) of the total diameter and I'd need another 1mm (again, .5 per side) to play with but I can always toss calipers on it before I just go cranking with the die.
          If you look at the top picture the threading is GONE at the bottom end. That may already be a total diameter of 1/2" / 13mm so a 1/2" tap may be too large.
          I'll just buy nuts in multiple sizes and see what fits.
          Patrick Henry
          • LJ851
            • 7918
            My 12X1.5 threading die measures 10mm ID so that would point to threads being 1mm tall radially so if your 14X1.5 threads are completely removed you could be around 12mm diameter currently. Either way, a quick measure of the shaft should point you towards the right die and nut.
            Lorin
            • AndrewBird
              The Mad Scientist
              • 11898
              An M14x1.5 thread has a minor diameter of 12.344 mm.
              You aren't going to be able to just thread an M12 die onto a shaft that isn't 12mm. It won't fit, and if you are able to force it, you will likely end up with fucked up threads in the end. If you don't have a lathe to turn it down, you might get away with spinning the shaft in a drill and using a grinder to get it close as a temporary solution.
              • phenryiv1
                • Jul 2009
                • 3246
                Good point. I am not going to pull the shafts to put it in a lathe. If I pull the shafts I'll spend the $42 on a new one.
                For now I was able to get the nuts secure enough to be hand tight with a socket wrench so it should be safe to drive to the body shop wednesday.
                I will be ordering a new shafts and the securing parts.
                Patrick Henry
                • jeffnhiscars
                  • Jun 2011
                  • 6010
                  It's the splines that insure that the steering wheel turns the column whichis your major safety concern and they look ok. all the nut does is keep the wheel from being pulled off the spline (not a minor function) so if you are determined to drive it without replacing the shaft I'd drill a hole in the shaft and put a large cotter pin through it. Any gap between the top of the nut and the pin I'd fill with shims....until you get a new shaft.
                  I suspect this is more secure that a half ass re thread
                  Alice the Time Capsule
                  • ///M42 sport
                    • 3952
                    if you replace the shaft, mind posting some pics of the process? THanks.
                    • Northern
                      I like cupcakes & sh!tboxes
                      • 5223
                      I wouldn't be concerned with rethreading it to M12X* unless you tend to haul yourself forward via the wheel for some reason.
                      That said, "Better safe than sorry" is a good motto.
                      Originally posted by priapism
                      Originally posted by shameson
                      • SmokeE30
                        • 1730
                        Only thing that's tricky is the snap ring at the top, I use a 18mm 1/2" deep socket and a hammer to get it, on an airbag car that is
                        Shawn @ Bimmerbuddies
                        Bimmerbuddies LLC
                        717-388-1256
                        2971a Roundtop Rd, Middletown PA 17057
                        bimmerbuddiesllc@gmail.com
                        • phenryiv1
                          • Jul 2009
                          • 3246
                          Now or in the near future I will be replacing it and I will document the process.
                          Patrick Henry
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            You could slice the threads off then drill and tap a hole down the center of the shaft and use a bolt instead of a nut. E34s are like this.
                            • phenryiv1
                              • Jul 2009
                              • 3246
                              I considered that but getting the hole drilled perfectly to allow for the tap to be square would be nearly impossible.
                              Patrick Henry
