guys, my 86es has developed a strange sound from the front end. sounds like the right side. you can also kind of feel it through the steering wheel. it's a low pitched droning sound like tire to road sound and the feeling is like someone layed a tuning fork to the car, not a shake or vibration. thing is, when turning to the right the slightest bit it goes away. to the left, maybe a little stronger. also changes when hitting dips in the road. the wheel does not feel hot after a long drive. i'm not very familiar with suspension or steering work so a little advise would be appreciated.
mystery noise from front end
Tags: None
Sounds like a bad front bearing to me. When you turn left, you're transferring the weight to the the right side, hence why the sound gets louder.
Fairly easy job. This is a good DIY: http://ilovemye30.blogspot.ca/2013/0...placement.htmlEstoguy
Need a photographer, come visit my site: http://estoguy.wix.com/unique-perspectives -
ok, so everything is goin good with the front hub replacement until the puller pulled the hub off and the inner race is still on the shaft. how do i remove this stuck on race????sigpicComment
Are you doing the rears or the front?2001 silver/Blk 325 cabby. SOLDOriginally posted by codyep3I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
2002 325xit Sil/blk. SOLD
2010 F650gs twin
2016 M235i cabby. Mineral grey/Red leatherComment
ok, for future reference, how should i handle the inner race if it fails to come off when the hub does?sigpicComment
Absent a puller Drill a small hole part way through the race and hit it with a chisel. It should break.
Did you remove the inner race of the new bearing and install the new hub with the old inner ?Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Comment
yes, installed new hub with old inner. and i have a pulle but there is nothing to grab onto on the old race.sigpicComment
I cut them part way through with a die grinder, or dremel. Place the chisel in the groove you cut, and smack it with a hammer. It will split in two and fall off2001 silver/Blk 325 cabby. SOLDOriginally posted by codyep3I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
2010 F650gs twin
