Replacing oil in front struts with Koni Sports
  • Klug
    • Sep 2011
    • 804
    Quick question- as we all know there is oil in the front strut housing that is used as a cushion. I drained and replaced the oil when I installed JOM coilovers (do yourself a favor and never buy them)
    I'm swapping in Koni Adjustable gas Sport struts now, however I'm reading off of pelican that for gas Bilsteins Sports you DO NOT add/replace oil- sounds like they get installed dry. Is it the same way for Koni Gas Sports? Just wondering before I jump into doing mine.
    Thanks!
    555Garage - Kingston, PA
    '13 BMW e70 X5 35d
    '95 BMW e34 525i
    '92 BMW e30 325i S52 Vert (Quade the Vert)
    '92 Range Rover Classic
    '90 Range Rover Classic
    '89 BMW e30 325i Coupe (The DIRTY30)
    '81 VW MK1 Rabbit Caddy Diesel
    '76 Honda CB550K Cafe/Brat
    '67 Pontiac LeMans
    '24 Model T Depot Hack
    ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
  • jeffnhiscars
    • Jun 2011
    • 6011
    You do not need oil. It's for transmitting heat to the housing with hydraulic shocks and is not required for your swap
    Alice the Time Capsule
    • Northern
      I like cupcakes & sh!tboxes
      • 5284
      Oil is for heat transfer between strut and housing.
      Bilstein sports are an inverted strut, so there is no heat to be transferred in the housing, however the bumpstop will eventually get destroyed by oil if it isn't cleaned out before install.
      The instructions that came with the iX Koni Sports says to add oil. Since there's no internal bump stop down there, and they're not inverted, it makes sense.
      Originally posted by priapism
      Originally posted by shameson
      • Klug
        • Sep 2011
        • 804
        Awesome- Thanks guys.
        '13 BMW e70 X5 35d
        '95 BMW e34 525i
        '67 Pontiac LeMans
