Steering wheel will not come off!
  • Berniesgotabimmer
    • Aug 2015
    • 16
    I'm trying to take my nardi wheel with momo hub off and I turn the key and wheel will not pull off. I don't know what else to try I already yanked as hard I could. What can it be?
    Thanks
  • DesertBMW
    • Aug 2011
    • 1042
    just got stuck on there then, use wd40 and a puller
    • Berniesgotabimmer
      • Aug 2015
      • 16
      Spray onto the splines?
      Just to be clear trying to take the wheel and hub off of the steering colum not wheel from hub
      • TimeMachinE30
        • Jun 2014
        • 3749
        Yes, spray the liquid wrench or lubricant where the resistance is.. this case, the splines. Be gentle. Don't want to ruin either set of splines!
        ACS S3 Build / Dinan 5 E34
        • Berniesgotabimmer
          • Aug 2015
          • 16
          No luck. You know how when you turn the key into first of second position it's suppose the release the hub? It's not releasing the hub for some reason. Is there any way to disable that?
          • uturn
            • Dec 2010
            • 1007
            If you can turn the wheel after turning the key then that steering lock is not holding it back. Just put that nut on(so the wheel won't hit you in the face) and give it a good yank.
            • AndrewBird
              The Mad Scientist
              • 11898
              Use a puller. It will come off.
              • jeffnhiscars
                • Jun 2011
                • 6011
                No one asked if he unbolted it :)
                Alice the Time Capsule
                • TimeMachinE30
                  • Jun 2014
                  • 3749
                  Reeeeaaaly hope this is not the case.
                  22mm. And "righty tighty, lefty loosey".
                  • Berniesgotabimmer
                    • Aug 2015
                    • 16
                    What's a puller?
                    Ha ha ha thats definitely not the case!
                    • TimeMachinE30
                      • Jun 2014
                      • 3749
                      Post a picture. Where do you stand in the realm of DIY'ness? Unbolt. Pull straight off. That's all you can do here.
                      • Mr. Tasty
                        • Jul 2011
                        • 3421
                        I have always used a rubber mallet to gently tap from all directions
                        2014 Alpine White 335i MSport
                        (Daily Driver)
                        Full Mperformance Aero
                        KW V2 Coilovers
                        VRSF Catless Downpipes
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          You do have to turn the key to disengage the steering wheel lock....after you unbolt the wheel :)
                          Just sayin
                          • Mr. Tasty
                            • Jul 2011
                            • 3421
                            Just sayin
                            You must have failed to read his first post.
                            (Daily Driver)
                            KW V2 Coilovers
                            • Big_sohc
                              • Feb 2016
                              • 6
                              i think its first key position not second... you've probably tried all that random s*** though lol
