E90 Drop Hats making noise. help!
  • Mike_z
    • May 2014
    • 60
    Hi guys,
    I'm having an issue with the e90 drop hats that I recently put into my e30.
    I lowered the car on H&R Race springs and Bilstein sport shocks and wanted just a tiny bit more low in the front. I researched these e90 top hats and had my friend mechanic install them with me.
    The problem I'm now having is that the there is noise on turning the steering wheel. What it sounds like is the spring moving around as I turn the steering wheel. I listened from the outside as well while he would turn the steering wheel and it sounds like the spring is being.. strained? or moved around in there.
    Now the question is, is there anything I can do about that? From what I've seen people didn't have much problems with this. It bothers me because you can not only hear it from the outside but you feel it in the steering wheel when the spring moves. If not, then I'll simply install the original top hats into the car.
    Thanks, Mike
    2008 E60 528Xi - Daily
    1991 E30 318iS S50 ///M
    1987 E30 325 [SOLD]
    Follow my build thread!
    http://www.r3vlimited.com/board/showthread.php?t=385058
  • Mushroom Stew
    • Dec 2014
    • 121
    Bumping this because I'm curious whether you were able to fix the problem? I'm thinking of running drop hats with the same shock set up and Eibach springs.
    • FireFight
      • Mar 2012
      • 1367
      the popping sounds isnt because the hats, i have had them in alot of cars, its because
      A) you tighten the top nut to tight so the spring plate cant turn with the assem. as you turn you wheel so the spring skips on it
      B) You forgot a washer so he spring plate cant turn with the assem. as you turn you wheel so the spring skips on it
      C)you didnt put the spring pads in and or didnt put the hat in the correct spot
      If its not a popping boinging sound and more that the spring is loose and moving around then you top hat isnt tight enough
      WTB:m60b40 in PNW
      Zachary Ripley
      85 318i M50B25tu.
      92 525it 5 speed.
      80 244gl (m60 prepping).
      • akorcovelos
        • Dec 2006
        • 1149
        2012 MCSCC/NSSCC CP class champ
        HSAX Instructor
        • DRTSRFR
          • May 2008
          • 1836
          Here we go again!;)
          Check the diagram in my signature for orientation of the washer.
          For some reason it is forgotten regularly.
          Suspension tips here...
          http://www.r3vlimited.com/board/album.php?albumid=757
          • King Mufasa
            • Sep 2012
            • 530
            Is number 4 on the diagram important as well?
            I lost #4 on mine and just assembled it without them..
            • jeffnhiscars
              • Jun 2011
              • 6011
              Without even looking at the diagram I'm going to take a wild guess and say...yes it's imprtant
              Alice the Time Capsule
              • getouth
                • Jan 2010
                • 3343
                I was iffy about drop hats because of this thread, installed mine 2 months ago and no issues I could t be happier
                FEEDBACK:
                http://www.r3vlimited.com/board/showthread.php?t=316212
                BMWCCA #398608
                IG @yagayo38
                "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
                • DRTSRFR
                  • May 2008
                  • 1836
                  All stock hardware should be re-used.
                  • Swendog
                    • Jan 2013
                    • 375
                    Ditto. Make sure to use all stock hardware (it's a good idea to use new locknuts) and don't forget the washer. Make sure the hats rotate freely. I put mine in a few months back with Billy Sports and H&R Sports and have had no issues whatsoever. Swen.
                    • Northern
                      I like cupcakes & sh!tboxes
                      • 5270
                      either wrong washer stackup, or your strut mounts are old and saggy so the drophat hits them.
                      Originally posted by priapism
                      Originally posted by shameson
                      • grinchxvx
                        • Dec 2015
                        • 295
                        Anyone just used any old washer instead of the BMW part number? I recently did springs and now I'm getting that "boing" sound when I turn at low speeds. Pretty sure I didn't do the washer stack right or don't have anything between mount and drop spring
                        • SkiFree
                          • Jun 2011
                          • 2766
                          As long as the ID fits snugly around the shaft and the isn't larger than the outside of the strut mount bearing.
                          ADAMS Autosport
