Would an 88 is have better suspension than 87 eta
  • dmb62
    • Oct 2015
    • 42
    I've been looking this up but unable to get a straight answer just wondering if it's worth swapping out the suspension or if the difference isn't even really noticeable also if there's anything else the is has better than my eta let me know what I should swap over thanks
    • 34844
    if it's original 28 year old worn out stock suspension, then no, it's not worth it - they are basically the same.
    • Dagamus(NM)
      • 620
      Depends. If both are on the stock original suspension they will be equally terrible.
      Really depends on your goals. If you plan on keeping the m20 get the iS, if you are going to swap and change the body trim and can save significant money by getting the eta then do that.
      Personally, I would get the iS. The trim inside and out should be much better to start with.
      Gun control means using both hands
      Sex, Drugs, Rock 'n roll. Pick two.
