front camber number after spring drop?
  • Rob Daman
    • Sep 2014
    • 104
    hi guys,
    I just lowered my E on IE stage 3 springs and wanted to know what were your camber numbers on the front after the drop on stock top hats?
    I'm trying to figure what I should tell the alignment shop to set the rear at. I want to go 1/2 degree less.
    thanks
  • DER E30
    • Sep 2013
    • 2347
    Front: No idea, whatever the car has. Measure it.
    Rear isn't adjustable, so the shop can't do anything to it.
    I honestly wouldn't worry about the camber in the front, only front toe as that's the only thing adjustable on the car stock...
    -Christian
    • Rob Daman
      • Sep 2014
      • 104
      i have my phone that i can measure but i was hoping that someone had their alignment sheet so I can get a baseline.
      i have welded rear adjusters so i can get it adjusted to my liking.
      i may just tell them to go 1/2 degree less in rear than the fronts.
      • iPee
        • Nov 2013
        • 190
        I can give you my alignments specs as a baseline reference. I'm on racing dynamics springs I believe. They are green and rusty so I can't see the brand, came with the car when I bought it. I'll take get the specs when I get home from work. I don't have any adjustable components so it'll be whatever the lowering did.
        • Rob Daman
          • Sep 2014
          • 104
          thanks! that works
          • iPee
            • Nov 2013
            • 190
            -1.36/-1.24 left/right
            • Rob Daman
              • Sep 2014
              • 104
              thanks!
