Sudden change in handling character
  • RdWing
    • Mar 2016
    • 32
    I just finished putting new M50 injectors in, went for a spin, and during the drive something changed, and there's now definitely something wrong with the suspension. It doesn't seem to be sagging especially on any corner, but turn in feels all mush and the entire car doesn't feel tight all of a sudden. Not tossable anymore. Took the big 85mph sweeping right coming out of the caldecott tunnel and felt like the back end was wobbling around, steering/loose.
    I took a back route today, twisty mountain road, slower speed. Typically I have a blast on this route, but I seemed to have to crank the wheel pretty far to get the car to turn. On-center response is almost nil.
    I'm thinking I should bang out the front control arms (M3 CAB's already done), inner and outer tie rods (since my wheel was slightly cocked to one side), and take a look at the RTAB's.
    I'd say it almost felt like hydroplaning on dry asphalt. Does anyone have some suggestions?
  • jt223539
    • Apr 2011
    • 139
    Are your rear upper shock mounts blown out?
    • digger
      • Nov 2005
      • 6197
      sway bar mounts busted?
      • RdWing
        • Mar 2016
        • 32
        I looked at the strut mounts under the tonneau cover. Pulled off the little rubber thing and look to be in great shape. Don't know how to check them further than that though without removal.
        Sway bar is a good idea, I'll have to check that tomorrow.
        • The White Guy
          • Jul 2012
          • 144
          Rear subframe mounts good?
