Ride height measuring
  • ajp340
    • Mar 2016
    • 62
    Guys, what is the best way to measure the ride height on the stock 1990 325is?
    Also, Does anybody know what a stock ride height measurement would be?
  • Terroth
    • Jul 2014
    • 22
    Middle of the wheel to the fender arch is pretty universal.
    • ELVA164
      • 4861
      You can also do ground to the bottom of the rounded part of the rocker, not the pinch seam.
      • AndrewBird
        The Mad Scientist
        • 11898
        Center of wheel to the body line is what I've always done. This way you can check for any rake as well.
        • ForcedFirebird
          • Feb 2007
          • 8300
          Early and late models have different arches, the answers below are more universal for the e30 platform. The early models and cabrios have different arch and pinch weld heights. The body line across the bottom of the door is the same for all. ~11" or so to the top of that line is what I just measured on 2 e30's here at the shop. One is on stock weaves with 195/60 14 (11"), the other is closer to~11.5" stock suspension on 205/40 17.
          john@m20guru.com
          Links:
