Eibach 16mm rear sway bar. Is it adjustable?
  • GermanEngineering
    • Oct 2009
    • 51
    All the pictures of the e30 eibach sway bar seem to be generic ones that do not show the actual bar. Does anyone have an actual picture of one or can tell me how it connects to the sway bar links. Do the eom sway bar links push right onto the bar or do I need some kind of aftermarket links? The way it looks in the pictures is that it has holes on the end for adjustable links, not stock ones.
    Bimmerworld
    Thanks in advance.
  • digger
    • Nov 2005
    • 6181
    it has holes for aftermarket links rod end types that bolt through. whiteline make a link that works that isnt a rod end.
    nobody makes adjustable rear for stock links
    • GermanEngineering
      • Oct 2009
      • 51
      I've never seen an adjustable aftermarket rear link other than the IE one but those the the sliding kind.
      My question is.. Does the eibach bar connect to the stock links?
      • reelizmpro
        • 9552
        Most aftermarket rear bars are adjustable and come with adjustable length links and hardware. ST for example even comes with trailing arms reinforcement plates. The increased size of the bar is the only thing I see that may prohibit you from being able to use the stock link but if a new one comes with the kit, why bother?
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
