Are camber plates nessasary?
  • Mike325
    • Mar 2006
    • 3685
    Like the title says. I was thinking of getting IE street camber plates to help out because of course my car is lowered:D How do they install? I see every thing but don't understand the plate with the slots in it. How does that install?
    Thanks. Pic for more clarifacation.
    Originally posted by Kershaw
  • Mike325
    • Mar 2006
    • 3685
    Hmmm, so it looks like the plate with the slots mounts over the strut tube in the engine bay (sorry, forgot actual term ) Am I right? Looks to be simple to install.
    Thanks.
    • StereoInstaller1
      GAS
      • 22679
      Basically, you remove the strut, attact the plate to the bottom of the strut tower, then remount the strut. It will raise the front of your car the same as the thickness of the camber plate.
      Luke
      Closing SOON!
      Thanks for 10 years of fun!
      • Mike325
        • Mar 2006
        • 3685
        Oh, so it goes under the strut tower?
        • StereoInstaller1
          GAS
          • 22679
          ya mon, under
          Luke
          Closing SOON!
          • JRKOUPE
            • Dec 2004
            • 3159
            I was under assump these ADDED neg camber?.........that wont help u if tru.
            • JPL
              • May 2005
              • 774
              i have wicked negative camber on my rear wheels. Is it the same process for the rear? obviously with a slightly different kit. As easy as bolt on?
              Originally posted by Hawt drift chick
              Yeah, i'm a good dude i swear, i just like to be balls to the wall.
              • mtechnik
                • 6156
                ya mon, under
                Luke
                been to Jamaica lately?..... :-D :-D
                • PiercedE30
                  • Apr 2005
                  • 4220
                  get the MotorForce ones, with my H&R Race springs I can dial out the negative camber to about 1.5 degrees if necessary, and go all the way in to somewhere around 7 or 8 degrees or something rediculous like that. That and the MF plates have a very short stack height.
                  My 2.9L Build!
                  • Tom944
                    • Dec 2005
                    • 150
                    Absolutely not, you can't adjust camber in the back by moving the shock. Your hub is connected to the subframe on two fixed places so it will not be possible on the top of the shocktower. You can adjust by using shorter subframe bushings, using an adjustible subframe, using excentric bushes or something similar.
                    Take a look under your car and you'll see what I mean I think.
                    E30 Euro-S50B30 Tracktoy
                    E30 M20B25 Drifttoy
                    • JRKOUPE
                      • Dec 2004
                      • 3159
                      sent u a pm!!!
                      • rolandmw
                        • Feb 2006
                        • 21
                        I have the IE street adjustable camber plates on my car. They mount on top of you existing strut bushing. You have to press out the existing bolts from the bushing and mount the camper plate on top of it.
                        I wanted negative camber and got about -2 degrees with the IE stage 3 springs. Not sure how much positive camber you can get out of them though.
                        Good luck
                        • nefarious7907
                          • Jan 2005
                          • 1170
                          I thought that one of the camber plates actually was supposed to lower your car like .5 in???
                          http://www.cardomain.com/ride/657387
                          • wazzu70
                            • Jan 2005
                            • 1143
                            The camber plates made to work directly with the 2.5" dia race springs should as they dont have all the rubbber to dampen road vibration like the stock mounts. The stock upper strut mounts are pretty large...
                            -Nick
                            M42 on VEMS
                            • JRKOUPE
                              • Dec 2004
                              • 3159
                              MOST add on fixed plts raise the car the ht of the plt.
                              More expensive adj plates for c/o suspensions can lower car. Its about "stack ht"........ MF has adj plates for oe type springs...ie HR...that seem to have good low stack ht.
