V-Maxx Coilovers
  • SA E30
    • 1248
    V-Maxx Coilovers
    Hey guys, I'm looking into some V-Maxx Coilovers
    Here is a link
    This website is for sale! stratmosphere.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, stratmosphere.com has it all. We hope you find what you are searching for!
    I see that, they only offer then for the E36 and Z3, but I'm pretty sure an E36/Z3 coilover will fit on an E30 ? ... the kit has the same setup as the Ground Control stuff, with a True coilover in the front, and an adjustable spring perch in the rear.
    Do u guys think these will work on an E30 ?
    I'm not sure if I've got this right, but is there cutting involved on the front strut... something about cutting and welding... cant quite remember, as I'm pretty sure the front strut on an e30 is one piece.
  • SA E30
    • 1248
    Taken from a reply on E30 Tech
    Although that loos good... I can get these over here in South Africa for about $600
    so less than half the price... and then I still need them to be shipped over here :)
    I always figured that if the springs are to soft, I know a company who will make me up some for a reall good price, to my spec :)
    Ok, I searched and I can't find anything about cutting the strut collar... but I know I 've seen it on the forum here before...
    I'm pretty sure that the E36/Z3 ones will work, as the Z3 has almost an identical rear setup to the e30.
    • e30sd
      Fistee
      • Jan 2004
      • 5517
      e36 front struts and spindles are two pieces. e30's are integrated. that's the only problem. unless you wanted to swap to all e36 stuff up front, and deal with caster and steering geometry issues.
      • SA E30
        • 1248
        No, I just want to use these coil overs that are designed for either the E36/Z3 on a e30 strut ?
        • SA E30
          • 1248
          Bump
          • Bryden
            • May 2011
            • 1
            Hi Iam the agent for V-MAXX coil overs in Cape Town you can contact me bryden.claassens@yahoo.com
