Loose springs - IE3
  • DarkWing6
    • Apr 2004
    • 7144
    Loose springs - IE3
    So I had my car up on a lift getting my tech inspection done when my buddy doing the inspection pushed up on my front tires to inspect the bushings etc in that area. He heard noise of metal on metal that sounded loose and we both thought "wtf?". we dropped the car down a bit and looked closer to notice that my IE3 springs are i guess you would say loose in between the top and bottom holders. I cannot remember from installing them, but both sides are the same and the top nuts on the struts are tight. Is this normal? I know the metal on metal is cause I have no spring pads, but there was a lot of room down there. I just want to make sure this is normal.
  • backtrail69
    • Jul 2005
    • 4471
    Both my car's are like that untill they are back down onto the ground. It is just because the springs are so much shorter than stock.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • DarkWing6
      • Apr 2004
      • 7144
      Thanks. That is what I thought. It has just been a few years since I looked at them that closely and it kinda freaks you out when you are taking the car to the track.
      :up:
      • Jand3rson
        • 37587
        I remember thinking the same thing when I first installed my IE's in the back, since they're so much shorter, when we put them in, they didn't reach top to bottom and I was thinking, "are they supposed to be like that?"
        • PeaveyBassist
          • Sep 2004
          • 3511
          Try putting in Turner's Jstocks lol. There is about a 2-3" gap at the top between the springs/spring hat before you set the car down.
          Will
          RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
          Welcome e30 (brilliantrot '90 325is) 12/23/06
          DaveCN = Old Man
          My signature picture was taken by ME! Not by anyone else!
          If people keep quoting me in their sig, I'm going to burn this motherfucker down.
          • egk2
            • 2426
            Normal.
            • James Crivellone
              Head Janitor
              • 6304
              How is this normal by any means? I've seen vehicles (e30's included) that if they hit a speedbump, pothole, etc can cause the spring to pop out of the hat really easily.
              The shock should be matched properly to keep the spring under a LITTLE tension when unweighted.
              my
              • egk2
                • 2426
                my
                My springs never popped out of the hats when the weight of the car was on them, never even came close. The only way I could see this happening is if you jump the car. Every e30 I've seen with IE's or any other significant drop had a gap when you lifted it up.
                • xLibelle
                  • Aug 2004
                  • 2673
                  if springs pop out from something like a speed bump, the valving is dead
                  stage 3's with stock pads sit tight enough to not be able to come lose
                  • DarkWing6
                    • Apr 2004
                    • 7144
                    my
                    If this is true, how would you solve the problem?
                    • Kruzen
                      • Mar 2004
                      • 5603
                      Obviously by running H&R Cup Kit :D
                      Who doesn't love a little BBQ?
                      Griot's Garage at a Deep Discount
                      • Mystikal
                        Wheel Fitment Expert
                        • 9602
                        my
                        99% of E30s running around tracks every weekend with GC's have front and rear springs that will be loose when you lift the wheels off the ground. The only time my springs didn't do that was when I had custom 7" rear springs sent to me (regular is 5.5").
                        They don't fall out, or very often at least.
                        • backtrail69
                          • Jul 2005
                          • 4471
                          Which isn't a very good choice either since its so soft and low..
                          :: PNW Crew ::
                          • egk2
                            • 2426
                            Really? I heard the cup kit is the ish?
                            • 02stu
                              • Jan 2005
                              • 872
                              2002's really have this problem since they are so high stock. Alot of people who install aftermarked springs will drill two wholes through the top of the spring perch and zip tie the sprngs to the perch so when you jack your car up your springs don't come unseated.
