How my trunkliner became a shock mount
  • B0ND
    • 94
    I had just gotten done installing my H&R Sport springs and Bilstein Sport shocks along with new e46 cabbie rear shock mounts. I'm driving along enjoying my new set-up (it really is great by the way) when I hit what I would consider a regular size bump and I hear a pop followed by some rattling noise coming from the left rear. I immediately slowed down and pulled over to check it out. This is what I found:
    I limped it home since I was really close, took off the trunk liner and removed the shock.
    I had attached the shock mount before putting on the dust cover and other rubber mount, once I realized this I tried to take off the shock cover off, but it was being quite stubborn so I finally decided to just go without the dust cover. I'm guessing that I messed up the shock mount when trying to get it off the shock...at least the shock mounts I was replacing are in good condition, so I think I'm just gonna use those (they look like they're e46 mounts too).
  • golde30
    • 11464
    umm, yer missing 2 metal plates that go above and below the RSM...at least thats what it looks like.
    IG: @Baye30
    • backtrail69
      • Jul 2005
      • 4471
      Aftermarket Shock Mounts FTW!
      :: PNW Crew ::
      '87 325 4dr, '74 2002
      • B0ND
        • 94
        What metal plates are you referring to? The z3 reinforcement plates were in place as can be seen in the 2nd pic, I didn't show them in the 3rd pic. And theres no metal plate below, it's a (paper?) gasket that fits between the shock mount and the sheet metal.
        • PeaveyBassist
          • Sep 2004
          • 3511
          See that metal washer that is concave on top of the shock mount? There is another one just like it that goes below that. Also, a bump stop.
          Will
          RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
          Welcome e30 (brilliantrot '90 325is) 12/23/06
          DaveCN = Old Man
          My signature picture was taken by ME! Not by anyone else!
          If people keep quoting me in their sig, I'm going to burn this motherfucker down.
          • B0ND
            • 94
            Are you running aftermarket shock mounts? If so what kind?
            • PeaveyBassist
              • Sep 2004
              • 3511
              Btw, I have brand new e46 cabrio mounts never mounted if you want them.
              Will
              DaveCN = Old Man
                • 34844
                you put them together wrong like others stated. I've had E46 cabby mounts in my car for 4 years, never had a problem with them.
                oh yeah, you really don't need a bump stop on the rear of an E30. I took mine out to make adjusting the konis easy..
                • backtrail69
                  • Jul 2005
                  • 4471
                  I have e46 cabrio mounts in my grey car and IE mounts in my eta. No problems with either..
                  :: PNW Crew ::
                  • golde30
                    • 11464
                    dude, get top adj rear konis, that would make it even easier...:p
                    IG: @Baye30
                    • K-Swiss
                      • Dec 2006
                      • 118
                      The guys are right. Your missing parts below the shock mount. The shock mounts are fine however the install you obviously missed some pieces. Anyways get the right spacer/washers, and a shock shaft cover and reinstall it and you should be golden. If need be look at the diagram on REALOEM to get some hints.
                      Cheers,
                      • B0ND
                        • 94
                        Got it sorted out now, thanks for the help.
