I need to go LOW
  • ian e30 318is
    • Mar 2007
    • 1809
    I need to go LOW
    Im looking for new springs and was looking at suspension techniques 60mm/40mm springs. I contacted them and apparently they dont carry them anymore. SO im looking for some STIFF springs that have a pretty large drop. I mean at least so there is no fender gap in the front with the basketweaves and 205/60's. thanks for the help.
    Ian
    1991 LS1 Swapped 318is
    Instagram:
    https://instagram.com/saltybeast/
    LS Build Thread:
    https://www.r3vlimited.com/board/for...s-e30-ls1-swap
  • Mastrcruse
    • Sep 2005
    • 5340
    Did you ask them about their 60/60mm drop? How much do you want to spend?
    • ian e30 318is
      • Mar 2007
      • 1809
      yeah they said 50mm/50mm was the lowest they had. Plus I havent really heard too much about them so i dont know how stiff they will be or what not. I am willing to spend under $300.
      Instagram:
      LS Build Thread:
      • Mastrcruse
        • Sep 2005
        • 5340
        Just for springs correct?
        • 808BMW
          • 2910
          To go as low as you want and have stiff enough springs to not bottom out on everything you'll need coilovers.
          • ian e30 318is
            • Mar 2007
            • 1809
            Yeh. haha. just for springs. i want to get coilovers but they arent in the budget at this point in time. I was looking at the intrax springs on backtrail69's car. has anyone tried or heard of these?? i think they are low enough based on their site. they advertise a 2.2"/1.5" drop for the '91 318is. anyone know who orders these is california?
            Instagram:
            LS Build Thread:
            • backtrail69
              • Jul 2005
              • 4471
              You really need coils. My car isn't stiff at all.
              :: PNW Crew ::
              '87 325 4dr, '74 2002
              • ian e30 318is
                • Mar 2007
                • 1809
                haha alright. maybe ill just have to wait then. do you know what the rates on your springs are?? the drop looks really good.
                Instagram:
                LS Build Thread:
                • backtrail69
                  • Jul 2005
                  • 4471
                  I am not sure, probably in between H&R sport and Eibachs...I got the springs from 4ce30 to use till I get my own coilovers.
                  :: PNW Crew ::
                  • ian e30 318is
                    • Mar 2007
                    • 1809
                    ok cool. thanks for the help. any other ideas for springs then??
                    Instagram:
                    LS Build Thread:
                    • backtrail69
                      • Jul 2005
                      • 4471
                      I would get a set of IE3 with bekker drop hats. That would be stiff enough and put you in the lowering range you want. A good set of bilstein sports or Konis is a MUST.
                      :: PNW Crew ::
                      • ian e30 318is
                        • Mar 2007
                        • 1809
                        i have bilstein sports and the bts springs but i hate em. is it hard to get the drop hats on? i want to get just the springs but if you think the intrax springs are not a good deal then i might try the drop hats.
                        Instagram:
                        LS Build Thread:
                        • backtrail69
                          • Jul 2005
                          • 4471
                          I have never installed them personally but I have heard there is minor grinding on the outsides to clear the strut towers (super easy), but It just bolts on top the spring on the strut. http://www.bekkers.com/Merchant2/mer...=blssuspension
                          I think those mixed with a stiffer spring like the IE3 it would be a nice low setup, but still stiff without dealing with coil overs.
                          :: PNW Crew ::
                          • ian e30 318is
                            • Mar 2007
                            • 1809
                            yeah i might try that. the only problem is i dont have anything to grind them down. ill look up some threads to see if anyone has posted about them. thanks for all the useful info
                            Instagram:
                            LS Build Thread:
                            • backtrail69
                              • Jul 2005
                              • 4471
                              Problem solved. :razz:
                              http://www.harborfreight.com/cpi/cta...emnumber=31309
                              :: PNW Crew ::
