KONI vs BILSTEIN
  • Apex381
    • Mar 2004
    • 740
    KONI vs BILSTEIN
    After many questions in response to me selling my set of Koni yellows for Bilstein sports, I think that we need this thread.
    I for one have always heard that Koni's are stiffer even on their softest setting than Bilstein sports. I have ridden in car equipped with both and agree with this idea, but this is just an observation from somebody who rode in the car casually.
    I found this interesting chart/slideshow here
    KONI is the world leader in adjustable shock absorber technology with over 50 years of worldwide racing success.
    Yes its a mustang but the concepts should be sound. The data on that slideshow certainly back up my impression that the koni's are stiffer.
    I know the Koni rears are monotube and the koni's are twin-tube, but dont know exactly how this would effect the handling of an e30. Some magazines have read mention that the bilstein sports ride better than the stock shocks (Bimmer has run this many many times). It seems the bilstein Sports have a soft initial dampening and then self adjust and firm up?
    I know there are people who know more about this than I do so chime in please.
    1987 325is - sold
    2001 330i - New DD
  • e21pilot
    • Apr 2004
    • 114
    Konis > Bilstien
    • Teaguer
      • Sep 2004
      • 6167
      I'll mention as wel that the Bilstein Sports have the SAME EXACT valving as the Bilstein HD's .
      Many believe the Sports are firmer , not true , they are only shorter to lessen the chance of bottoming out the piston with lowering springs .
      With the kOni v Bilstein it really depends what you are after , but since most of us want a firmer ride I think that makes the Konis a clear winner .
      Plus they are adjustable , even if you have to undo the lower bolt in the rear and spin the shock that is stil one up over the Bilsteins .
      Koni = clear winna .
      • matt
        • 3732
        Bilstiens are better shocks, konis are better setup for our cars.
        Revalved bilsteins are really the way to go.
        • asubimmer
          • 6482
          bilstein > koni
          • egk2
            • 2426
            I've always believed Konis were softer than Bilsteins.
            • Apex381
              • Mar 2004
              • 740
              yeah and I hear revalving them is actually pretty cheap
              1987 325is - sold
              2001 330i - New DD
              • StereoInstaller1
                GAS
                • 22679
                I was quoted about $300 for all 4.
                Closing SOON!
                Thanks for 10 years of fun!
                • Apex381
                  • Mar 2004
                  • 740
                  ok maybe not
                  1987 325is - sold
                  2001 330i - New DD
                  • e30polak
                    • 6136
                    konis are only better if u order the ones that are rear top adjustable as well
                    INSTAGRAM: @UNDR8D_EMPIRE
                    • boom-monkey
                      • 1104
                      It's actually $60 a shock, so $240.
                      • Jon325i
                        • 6934
                        Yep - sounds right. I have revalved B-Sports paired up with IE Stage 3s. I also have TreeHouse Racing CABs. The sways are stock and no camber plates installed either. Ride quality is firm by livable for DD usage (at least I think they are.....opinions may vary). I've tracked this set up a few times while rolling on Azenis Sports and it was decent for what it is. Bigger bars would dial out some body roll and some other tweaks would improve things for sure.
                        As for the B-Sports themselves? Good product - not a single problem. If my car were more of a dedicated track car then adjustable Koni's would be the way to go - but for a car that's mainly used on the streets, B-Sports are more than up to the task.
                        Jon
                        Rides...
                        1991 325i - sold :(
                        2004 2WD Frontier King Cab
                        RIP #17 Jules Bianchi
                        • 1990m3
                          • 1180
                          Bilstein > Koni. I have a set on each car and I hate the Koni's. Bili sports all the way for me. I had them revalved this winter to match my J-stock springs I bought and it is fantastic. Car is on rails at the track and feels great. BTW, it was $60 per shock for revalving.
                          • PaintPro21
                            • 660
                            The complaints we here rutinely is that bilsteins are too stiff in comparison to koni shocks.
                            Bilstein's use an inverted shock body and do their dampening on the compression stroke. This means that the shock is actually adding to the spring rate. and the inverted shock body means that the shocks is sealed in its own housing and you can't see when it's leaking. The bump stop is contained in this housing and it gets soaked with hydraulic fluid which then makes the shock hit an extremely ridged bump stop.
                            Koni's do their dampening on the rebound stroke. This allows the spring to do it's dampening at the rate it was designed for. (if you want a soft ride you install soft springs, if you want a stiff ride you install stiff springs) then on the rebound stroke it controls the spring and prevents it from bouncing back too fast giving the car a springy feeling.
                            I run a koni/GC setup and sold off my Grp.N suspension that used bilstein shocks.
                            ApexRaceParts.com - Facebook - Twitter
                            • romkasponka
                              • Oct 2006
                              • 8
                              Do not agree with you PaintPro21. Nothing depends in damping because of inverted or traditional shock. Bilstein adds 1% to spring ratio or even less because of nitrogen pressure. Bilstein has two seals and to damage it is not so easy.
