cutting H&R race springs
  • bignate948
    • Apr 2006
    • 542
    i know that you cant cut regular srpings, but i thought that i read some where that you can cut some off of the the H&R race with out affenting the handling of the spring/car
    and if it is true how much can you cut them and how much more will it lower the car?
  • JGood
    • Jan 2004
    • 7959
    You can cut whatever you want. What you can do and what you should do are 2 very different things.
    And why would you cut a set of $400 springs?
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • PiercedE30
      • Apr 2005
      • 4220
      It's somewhat common to cut half of one of the dead coils from the front to bring it down about a 1/4"-1/2". Do a search on S14.net and you will see a bunch of topics on it.
      My 2.9L Build!
      • parkerbink
        • Jun 2004
        • 10134
        I hope you have a skidplate under your oil pan.
        • Van Westervelt
          • 9365
          cut springs = cut corners
          • JGood
            • Jan 2004
            • 7959
            If you cut half a coil, how will it sit properly in the perch?
            • Van Westervelt
              • 9365
              The upper perch rotates freely 360 degrees.
              • JGood
                • Jan 2004
                • 7959
                ahhh... I knew that ;)
                • 92 mtechnic cabrio
                  • 4907
                  sell the springs to someone else and buy a different pair of springs, eat like twenty bucks difference
                  R.I.P 07/01/09 - 04/23/10 :(
                  • JGood
                    • Jan 2004
                    • 7959
                    Yeah, a 60mm drop is probably exactly what you are looking for... and can be had for $200, not $400 + cutting good springs
                    • DCColegrove
                      • 2748
                      Ummm....
                      No...
                      Not a good idea.
                      Call H&R I'm sure they will tell you why.
                      I doubt anyone would (or should) listen to anything here.
                      • Garageaholic
                        Freestyle Fabricator
                        • Dec 2005
                        • 5204
                        The spring constant, k, changes because the number of active coils, N, changes. Although small, it does make a difference.
                        Do a quality job, Don't cut the springs. Get a 60/40 kit
                        Recent Rebranding!!
                        E30 SM62/S62
                        E30 M60 V8
                        E30 M30 Big 6!
                        Instagram.com/garageaholic
                        Youtube.com/garageaholic
                        • PiercedE30
                          • Apr 2005
                          • 4220
                          K doesn't change because you still have the same number of active coils, unless you cut an active coil, which is why people cut one half of a dead coil from the top. It's been done before. If you want numbers, I can find them. Let me do that for ya real quick....
                          edit: If you were to cut ONE FULL dead coil, you might increase the stiffness by up to 10% (goes from 350 to 385). But since we are only talking a half of a dead coil, at the most it would increase stiffness to 370, and it would lower the front of the car just enough to even out the stance. With my H&R Race springs I have about a 1/2" gap between my front tire and wheel well, see sig, and I have a total of 3 spring pads in the rear, one on bottom and two on top, and there is no gap between the tire/wheel and the fender well.
                          My 2.9L Build!
                          • Todd Black 88
                            • Oct 2007
                            • 3449
                            I have a set of very low springs from my M3 for sale if your interested. The car is now on h&R sports, and the car sits about 2" higher now on the sports than it did on these springs. i have no idea what they are(cannot find numbers on them) But they are low.
                            PM if interested.
                            Originally posted by codyep3
                            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                            2001 silver/Blk 325 cabby. SOLD
                            2002 325xit Sil/blk. SOLD
                            2010 F650gs twin
                            • GoKart
                              • Jan 2008
                              • 136
                              PM if interested.
                              PM sent!
