Any way to go lower in the front with IE III springs?
    Originally posted by Mr. Anderson View Post
    My fronts are already rolled pretty flat, but I think I might actually roll them again and try to pull them out some.
    I'm considering selling the IE3's this winter and getting coilovers.
    :tsk::borg: :wgaf::hitler::(:p
      Originally posted by xLibelle View Post
      Why move away from a ride height that is pretty much as close to being "right" when it will cost you more time and money to manipulate it a mere cm?
      Why not spend it on more important things like rear alignments or improved steering characteristics first?
      You sir make far too much sense for this thread.
      Mr. Kind Administator, have you already abandoned the use of spring pads?
        You may be on to something there.
        91 318is
          You can use spring pads to corner balance on a non-adjustable system
            just found these... might be promising
            e30sport.net
            '06 M3 Competition - 6-speed
            '97 Range Rover Vitesse
              those are probably the same as the Bekkers hats. they work fine, just require a lil trimming around the edges to make them fit rite.
              IG: @Baye30
