Ground Control RSM vs. IE Billet RSM
  • submwar
    • 216
    GROUND CONTROL RSM vs IE BILLET RSM
    How do these two COMPARE?
    • 34828
    neither
    TCK :p
    • DSP74
      • Nov 2007
      • 1121
      The TCK option has rubber bushings which is a plus IMO.
      In this instance rubber or spherical bearings are the best choices
      88 325is
      • Hellabad
        • 807
        Compare.
        To answer the original question:
        There are several differences, the most important I think is that the Ground Control RSM is made for an e30, and the IE seems to be "universal". The GC reinforcement bracket is for an e30, but the IE looks like it is for an e36. I can only guess, but it looks like an e36 part sold for an e30.
        Somebody mentioned TCK, but that is also universal, and has no reinforcement at all. Plus the bolts need access from the trunk, which nobody else requires anymore. As far as rubber vs urethane goes, any RSM is a good application for urethane. There is no twisting or rotation involved on an RSM, so the squeaking that comes from most urethane suspension bushings won't happen with any urethane RSM.
        Monoball rear shock mounts are just silly for anything that is not a full blown race car, and even then you need some expensive shocks to have difference, let alone feel the difference. Monoball RSM will --always-- make tons of noise.
        I have measured the deflection of a GC RSM on the dyno vs a monoball vs a rubber one, and the deflection is:
        Monoball: 0.0
        GC.0.007
        rubber (buna!) 0.120
        Ground Control for an e30
        Ireland Engineering
        Tc Kline
        Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
        Ground Control Gallery
        The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
