Koni Part Numbers
  • eLKuRLy
    • Oct 2007
    • 360
    which part # is the G60 corrado shocks?
    Is it 8641.1198SPORT ?
    • eLKuRLy
      • Oct 2007
      • 360
      anyone?
      • jaywood
        • Jul 2010
        • 4528
        8641-1198-Sport
        • iamsam
          • Jun 2008
          • 176
          I am bumping this, because I am about to order a ton of Konis, and this crap is throwing me for a loop.
          1. So M42 and M20 strut housings are different??
          2. Which shocks will I need for a 1990 318i? the 8641 1021 and 80 2522 combo, or the 8641 1210 and 80 2641 combo??
          I talked w/ a rep at Koni who was genuinely confounded and did not have an answer for me when I asked why there are different part numbers for different E30s, but gave me length and stiffness specs for the shocks.
          8641 1021 / 80 2522:
          485/614 mm compressed/expanded length
          500/750 N compression/rebound stiffness
          8641 1210 / 80 2641:
          488/585 mm
          700/750 N
          • jaywood
            • Jul 2010
            • 4528
            488/585 mm
            700/750 N
            Some early models have 45mm strut housings
            Your '90 will have 51mm strut housing.
            • iamsam
              • Jun 2008
              • 176
              ^^ yes, the part numbers listed above are all for the bigger diameter strut housing, and that wasn't my question.
              why did someone state above that 4 cyl and 6 cyl strut housings are different? is one longer than the other? They can't be, they have the same realOEM part number, I checked. So why, then, do some Konis work and some don't, and why are there different shock part numbers for different (seemingly identical) E30s?
              • iamsam
                • Jun 2008
                • 176
                bump, anyone have any definitive info on this??
                • iamsam
                  • Jun 2008
                  • 176
                  anyone?
                  • iamsam
                    • Jun 2008
                    • 176
                    seriously? no one?
                    • johnwoo
                      • Oct 2007
                      • 613
                      I think the 318i with the m10 had the smaller diameter struts the m42 is the larger diameter like the m20
                      • m_dudey
                        • 267
                        488/585 mm
                        700/750 N
                        this is really good info. though i'm a little bit confused about the numbers. In either case, are those length and stiffness numbers for the front or rear shock (i.e. 1021 or 2522)?
                        • Solarian
                          • Oct 2012
                          • 121
                          Bumping this as well for the same reasons. I want to get Konis but if I don't know for sure I'll just get Bilsteins. Did OP end up buying some shocks? Has anyone bought Koni shocks and installed them on an 318IS? (M42)
                          • iamsam
                            • Jun 2008
                            • 176
                            my brother in law bought the shocks for his '91 318i. It was such a long time ago I can't remember what conclusion we came to.
