Upgrading the rear shock mounts
  • royalflush313
    • Mar 2004
    • 2070
    I will be doign some work on the car, and I wil be replacing the rear shock mounts.
    I was informed that Z3 rear shock tower reinforcement (http://e30m3performance.com/installs...port/index.htm) mite be a good upgrade. Should I use it with the stock rsm or a cabrio/e46M one?
    opinions?
    thanks.
    ~ Go Canucks Go! ~
  • royalflush313
    • Mar 2004
    • 2070
    bump
    ~ Go Canucks Go! ~
    • DanGillan
      • Mar 2004
      • 4061
      use the "heavier duty" cabrio rsm, our stock rsm's are known to be "weak points" i know I havent had a problem with mine, but there's no harm caused in using heavier duty stuff, I dont personally know about the z3 plates, but i've read that they add rienforcement, so why not try em? your on the right track...
      Dan
      • aaron_silva
        • 1785
        So your telling me that the Z3 reinforcement plates add reinforcement?
        Aaron
        • DanGillan
          • Mar 2004
          • 4061
          Aaron
          he was asking an obvious question, i gave him an obvious answer...
          Dan
          • m42technic
            • 1056
            Aaron
            He asked if they are a good idea, not if they "add reinforcement."
            Anyways, the tried and true OEM setup seems to be E46 M3 RSM's w/ the Z3 plates. If youre not running a too wild suspension they should work just fine.
            James Peacock
            WWFSMD?
            • royalflush313
              • Mar 2004
              • 2070
              actually i wanted to get an opinion from people running stock mounts with the z3 reinforcements.
              Or I could just get e46 cabrio mounts on its own.
              From what i gathered, I don't think i need both the cabrio mounts AND the z3 reinforcements for the setup i will have.
              ~ Go Canucks Go! ~
              • m42technic
                • 1056
                Why not? New E46 M3 mounts are cheap, it really cant hurt.
                James Peacock
                WWFSMD?
                • Digitalwave
                  is a poseur
                  • 6292
                  Rear shock mounts need to be replaced sooner or later anyways, might as well go with the E46 M bits.
                  RISING EDGE
