Rear sway bar reinforcement
  • 318daily
    • 507
    Originally posted by Tony S
    Those look pretty badass. That's the first i've heard of those mounts going through the trunk (which is probably the cause of confusion). They probably work very well.
    You would be the first person I'd know of to use those, and at $125/pair I doubt many people on this forum would have them.
    I'll try to snap a pic of the ST mounts tonight just to give an idea of what they look like.
    • demlotcrew
      • May 2004
      • 297
      Originally posted by C ///M
      GET THE IE SWAY BAR SET. It is by far the most beautiful set of swaybars that money can buy for the e30. 25mm hollow 3-way adjustable front bar with adjustable links, 22mm hollow completely adjustable rear bar with adjustable links. The bars are stronger than other bars but lighter as well. The reinforcements that go through the trunk are fucking beefy as hell. I LOVE THEM.
      I dont see how a hollow bar could be lighter/stronger and still be better, i think its a alot of advertising crap.
      Andrew AT E30zone.co.uk | H23-is | S14
        • 34834
        I've been told by everyone that the rear IE bar is 22mm solid, not hollow?
        • C ///M
          • 1040
          IE advertised a solid bar for the rear, but when i got mine, both the front and rear were hollow.
          Both bars are incredibly thick and the hollow center isn't very big. It saves a little weight and I'd be willing to make a wager that they're stiffer than all the other bars for the e30.
          332iS R.I.P.
            • 34834
            I've been favoring the IE rear bar for my car, but everyone always says they are too big.. of course none of them actually own one ;)
            • C ///M
              • 1040
              It's not too big. Trust me. But then again, I don't know the deal with the iX. Do normal e30 sway bar kits work for you? If so, then i'd recommend you get the IE front and rear kit. It comes with the links and the rear enforcements (both the triangular weld-in pieces and the trunk bolt through) for $425. It's pricey, but includes those $125 rear re-einforcements.
              332iS R.I.P.
                • 34834
                not the front, just the rear. the front can be modified, but I don't think I need a lot more front bar.
                • clavinZERO
                  Hella sick E30
                  • Mar 2004
                  • 2027
                  these are the IE parts that I am running...
                  nice quality IMHO.
                  necessary? didn't wanna find out.
                  "BMW Style 32 Poster-Child"
                  HTTP://WWW.CLAVINZERO.COM/e30-5-lug
                  **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
                  • Tony S
                    • Apr 2004
                    • 88
                    Nice pics of the reinforcements.
                    How hard were they to install
                    • C ///M
                      • 1040
                      Easy as pie for me.
                      332iS R.I.P.
                      • Mtriple
                        • 3139
                        I've got the Turner's and they were a complete bitch to install...
                        Originally posted by Simon S
                        • E30-323ti
                          • 328
                          Mtriple: What shocks are those on the rear??
                          Do they run upside down??
                          292rwhp E30 :D
                          • Mtriple
                            • 3139
                            They are Turner valved Bilstien's. Turner refers to them as J-stocks....
                            Are they upside down? I dont remember what the struts I had before looked like...
                            • E30-323ti
                              • 328
                              Usually the body (large dia. outer part) sits at the bottom, like Koni's & stock shocks for example.
                              What rate rear springs do you run with them?? 400, 500, 600??
                              292rwhp E30 :D
                              • Mtriple
                                • 3139
                                Ok, yeah they are inverted then...
                                Not sure what the rates are, It's Turner's J-Stock package with there own custom wound H+R springs
                                http://www.turnermotorsport.com/html...D=E30TMSJSTOCK
