I'm gearing up to pull the rear subframe this winter and replace anything I end up touching back there.
- Replace all bushings on the rear subframe
- Replace the rear shocks and springs
- Replace the rear wheel bearings
- Replace the open diff with a LSD
I'll also do the front shocks and springs at the same time.
Looking at the parts I'm ordering and the list above, is there anything else I should do while things are apart?
Here's the list of parts I'm looking at ordering:
Rear top shock mounts
(Myele) https://www.fcpeuro.com/products/bmw...e36e46mountkit
Rear swaybar links
(Meyle) https://www.fcpeuro.com/products/bmw...-33551126932my
Rear wheel bearings
https://www.fcpeuro.com/products/bmw...-33416762317oe
https://www.fcpeuro.com/products/bmw...ar-33411138648
https://www.fcpeuro.com/products/bmw...er-33411124945
https://www.fcpeuro.com/products/bmw...ut-33411125664
Front Wheel Bearing/hub
https://www.fcpeuro.com/products/bmw...-31211131297my
https://www.fcpeuro.com/products/bmw...nt-31211125826
https://www.fcpeuro.com/products/bmw...ap-31211126790
https://www.fcpeuro.com/products/bmw...nt-31211130125
Shocks
Bilstein B8 Shocks
Springs
H&R OE Sport Springs
Rear spring pads
https://www.fcpeuro.com/products/bmw...ar-33531136386
Rear Sway Bar Bushings
https://www.powerflexusa.com/shop/pr...ing-16-mm-3152
Garagistic complete bushing kit
Front control arm
Differential mount bushing
Rear trailing arm bushings
Rear subframe bushings
Garagistic chassis reinforcement kit
Bump Stop (Front)
https://www.fcpeuro.com/products/bmw...-31331124449oe
Bump Stop (Rear)
https://www.fcpeuro.com/products/bmw...36-33521125078
Strut Mount (Front)
https://www.fcpeuro.com/products/bmw...nt-31331139452
Thanks
