Uneven rear height
  • VitalkaE30
    • Aug 2012
    • 238
    Uneven rear height
    Been truing to figure out what's causing uneven height in the rear. All bushings are new (poly) also have camber/toe kit welded in. Driver's side sits 1-1.5 inch higher than the passenger's. Have Catuned coilovers all around. First I thought the springs went bad, so ordered a set of swift springs and that didn't help. I had to remove the perch completely on the driver side and raise the adjuster on the passenger side about 1.5 inch in order to have somewhat even height. When I jack the rear up by the diff, driver side goes up before the passenger side. Any ideas? TIA
  • moatilliatta
    • 6151
    Where do you have your adjusters set to?
    photos of setup?
    @Zakspeed_US
