Style 5's on e30 with e36 m3 brake fitment?
  • bmw_builds
    • Oct 2017
    • 14
    I have a 1991 318is that is s52 swapped and 5lug swapped on ground control suspension and m3/z3m swap parts. I am currently on 17" style 32's with 225/45/17 Bridgestone Potenza tires. This setup does rub while turning without being at full lock and the coilovers are as high as they go. I would like to upgrade to better summer or track tires and lower the car for better handling. Will Style 5 Wheel 16x7.5 ET20 fit over m3 brakes? And can anyone provide me with measurements of inner barrel circumference I can measure against the brake caliper circumference? I have read on multiple different forms about this fitment but nobody is certain. It is all guessing that this is close but "usually" works.
  • moatilliatta
    • 6151
    Note: You’ll need 12.5mm front spacers to match the rear track with Z3M arms and E36M front.
    https://www.bimmerforums.com/forum/s...s-on-an-e36-m3
    It’s noted here E38 style 5s cleared E36M front brakes.
    What setup you have for the front can effect if you rub the fronts or rear of the inner fenders.
    @Zakspeed_US
